Introduction: The Inclusive Diabolo, Circus Is for Everyone - Production Manual
The inclusive diabolo is an addition to an original diabolo that ensures that everyone can have fun with circus tricks.
It can be used by everyone: beginners, experienced circus artists, duos, children, the elderly, people with disabilities, …
- Non-stretch cotton fabric; 95x46 cm twice (preferably upcycled, fabric you no longer use)
- Thin sewing elastic band; 40 cm twice
- Sewing machine and sewing supplies
Step 1: Cut Out Fabric
Fold the fabric in half and cut out a rectangle of 95 x 46 cm, so that you end up with two separated identical rectangles on top of each other.
Tip: it can be easier to cut out an example pattern out of an old newspaper.
Step 2: Folding Width
Fold the fabric 7.5 cm inwards in width, on both sides.
Step 3: Handle
Cut a handle from this pleated piece of 4,5 x 10 cm, and fold it inwards. This on both sides.
Step 4: Folding Length
Fold the fabric 1.5 cm inwards in the length, on both sides. Fasten it with pins.
Step 5: Sew Length
Sew the length twice starting from 10 cm, first time 0.3 cm from the edge. In addition another 1.3 cm from the edge. On both sides.
Step 6: Sew Width
Sew the width on both sides, taking into account the opening for the diabolo sticks. View the attachment for a detailed sewing instruction.
Step 7: Insert Elastic
Insert an elastic (40 cm) through the length using a safety pin, on both sides.
Step 8: Sew Elastic
If the end of the elastic is just visible, sew it well.
Step 9: Sew Elastic
Keep pulling the elastic with the safety pin through to the end. Remove the safety pin when it is through and sew the elastic tight.
Step 10: End Result
If you followed these steps you will get this as the end result. Have fun.
Step 11: Optional; Iron-on Stickers
If you also want the stickers on the fabric for easier use, then you will have to follow the following steps:
- download the pdf below
- insert this file and your flexfoil into a cutting plotter in a public fablab (for example MaM Brugge)
- follow the manual to use this plotter (can be found on the website of the fablab)
- once the stickers are cut, remove the excess materials
- lay the stickers shiny side up on the right spot and place a sheet of baking foil on top
- go over it with an iron for a few seconds, safely remove the plastic foil from the sticker
