Introduction: The Jet Model
This is a model and does not fly too far , but it is good to keep in your showcase if you are collecting paper airplanes. This is my first upload in instructables.com and I hope you like it. I took the pictures with my Nintendo 3DS so I hope it is clear.
Step 1: Materials Needed
Just Take an A4 size sheet. It's more than enough!
Step 2: First Fold
Fold it into a half and crease it well.
Step 3: Opening
Open it up.
Step 4: Triangle Fold
Fold it from the left corner to the line you made with the crease(usually done to most paper airplanes).Do the same process for the right corner.
Step 5: Small Fold
Fold the lower-right corner and the lower left corner.
Step 6: An Equilateral Triangle
Fold the lower part upwards until it looks somewhat like an equilateral triangle.
Step 7: Upward Fold
Fold the lower right corner to the topr point. Repeat the same process for the lower left corner. Then Turn it back.
Step 8: X Diamond
Fold the middle corners and bring it to the center.
Step 9: A Little Push
Now this is the complicated part. You have to push the back, and put it in. I hope you get the result as the second picture. It's not very clear.
Step 10: The Final Touch
If you were able to complete the nineth step you can now make the wings - Which you all should be knowing.
Step 11:
At last complete!!! I hope you all liked it. My suggestion is to put it up on your showcase if you have on. It's your choice!!! Enjoy!!!
