Introduction: The Recyclable Candy Dispencer
Why I made it:
- I made a recyclable candy dispenser because a lot of people eat candy especially kids and my reason being is you don't want someones hands touching your candy. Like for example I was gonna get m&ms and my cousin just came from out side and he touched all the candy and i didn't want know more because his hands where dirty and had germs on them. I did not want it happening again so i made a solution I made a candy dispenser out of recyclables it was really easy and all you need is recyclables laying around the house and two supply's u can buy.
Step 1: How to Build the Candy Dispenser:
Step 1 :
- Get your supply's
You will need foam board or card board 12 x 12 cm.
paper / plastic cups.
Hot glue
Hot glue gun
Exact o knife
Ruler in inches
Step 2: How to Build the Candy Dispenser:
Step 2:
Heat up your hot glue gun so you can later on put every thing together.
Step 3: How to Build the Candy Dispenser:
Step 3:
Get your foam board and get your measurements and get four even squares of foam bored its later gonna be the base of your candy dispenser.
Step 4: How to Build the Candy Dispenser:
Step 4:
Cut out the foam board into even squares.
Step 5: How to Build the Candy Dispenser:
Step 5:
Get the preheated hot glue gun and glue all the pieces together and that will make your base.
Step 6: How to Build the Candy Dispenser:
Step 6:
Get your two cups and hot glue them together too make the dispenser.
Step 7: How to Build the Candy Dispenser:
Step 7:
Cut out a little tab at the button of the cup
Step 8: How to Build the Candy Dispenser:
Step 8:
Put the dispenser in the base and hot glue them together.
Step 9: How to Build the Candy Dispenser:
Step 9:
Cut a hole at the top of the dispenser.
Step 10: How Too Build the Candy Dispenser:
Step 11: Pros and Cons
Pros:
- Eco friendly
- recyclable
- reusable
- safe
- remake able
Cons:
- time consuming
- non cleanable
- can break easily
- can only hold a small portion of m&ms
Step 12: Conclusion :
In conclusion my project is an improvement on a normal candy dispenser. A benefit to the user of this item cause instead of people reaching in your bag of M&M's with their dirty hands they can use a dispenser reduce spread of disease. Also you can make it out of anything such as foam board, card board, plastic or paper cups . It is also healthy for the environment being it is recyclable and can be reused. It can be reused as Foam board and paper products such as paper plates.
5 years ago
I hope he doesn't steal any more of your candy :)
