Introduction: The Corset Pattern Generator
This is a guide to using the corset pattern generator, made by Mette Wikkelsø from http://largerthanlifedress.blogspot.dk/
This is not a finished pattern!
The generated pattern should not be used without a mock-up, as it only takes into account the total measurements of the body, and not any asymmetries, or if the wearers bodytype varies from the corset style used.
The generator is based on the free guide to making corset pattern from Foundations Revealed.
Step 1: Get the Program
The generator is based on processing, a small program that can be downloaded from processing.org and used to program drawings. In order to use the file, you need to download the program to your computer.
Step 2: Enter in Your Measurements
Open the file 'corset_generator_version1.pde' in processing and save it. In the top of the file, there is a section marked 'enter in measurements'.
Here you enter in the different variables in millimetres:
Waist reduction
I recommend 50 mm for new users.
Horizontal measurements, that is your unreduced, uncompressed measurements.
I recommend to measure the wearer in a good bra, without any padding.
Vertical measurements, that is the distance between each horizontal measurement.
I recommend that 'waist to high hip' and 'waist to low hip' are kept at 70 and 140 mm each, and that you measure the wearer at these distances from the waistline.
Seam allowances should be your preferred.
Step 3: Name Your Pdf File and Generate It!
Scroll down in the file until you find the section 'enter the name of the pdf file'. Enter in the name you want for the pdf file.
Now you are ready to generate your pdf file with your personal pattern. Simply click the play button in the top of the program and it will be generated. A new window will open with a preview, but simply close this, and find your pdf in the same folder as the program is saved.
3 Comments
2 years ago
dont work with processing-3.5.4
7 years ago on Introduction
I downloaded the program, but I can't seem to find a program to open the corset generator. I found one but it's garbage. Any help?
I have made an online version, you can find here:
http://www.imagio.dk/corsetdesigner/corsetdesigner...
That should make it all a lot easier:)
If you want to print the pattern on paper, you might have some issues with the SVG file if you are not used to vectors, but just convert it to a jpg and print it from a drawing program.
