Introduction: Tie-Dyed Underwear
The perfect Father's Day gift. Easy to make, and a great surprise for your dad. With these brief you'll always look your best.
Step 1: Material
For this instructable you will need:
5 to 10 pairs of plain white briefs
1 Tie-dye kit
1 bag of rubber bands
1 Tie-dye kit
Step 2: Rubber Banding
To make really cool patterns on your Dads undies you need place rubber bands on the underwear like the picture.
Step 3: Mixing Dye
The tie-dyeing kit should contain instructions (if your kit has directions you should probably use those) . But if it doesn't the directions are pretty much universal.
1) Fill the plastic bottles (that should be in the kit) with water. You can also use a small plastic bottle.
2) Mix in the dye. The die should be in powdered or liquid form.
3) shake the bottles until the dye is thoroughly mixed.
Step 4: Applying the Dye
To apply die you can pour (or squirt with squirt bottles) dye onto each portion of the rubberbanded underwear. For the best result apply a different color to each section and thoroughly cover all the white.
Step 5: Setting the Dye
For my kit I had to rap the finished product in plastic for 6 to 8 hours. Than wash them in the washer. Don't put your new undies in with other clothes until the ink is set other wise you may ruin your other clothes.
Step 6: Closing
I hope this instructable works out for you and I hope to see some pictures.
