Tin Foil Bird
1,670
Introduction: Tin Foil Bird
Make a bird out of tin foil
Supplies:
12 inch roll of tin foil
Pins
Black circular piece of plastic with 1/8 inch diameter
Toothpicks
16 inch piece of packing styrofoam
Step 1: Crunch
Crunch a 17 by 12 inch piece of foil
Step 2: Shape the Foil
Shape foil into a bird shape, head, body, and tail
Step 3: Add More Aluminum
Add more aluminum foil on the body
Step 4: Add More Aluminum
Add more aluminum to the head and shape it
Step 5: Clip the Tail
clip the tail to size
Step 6: Insert Two Tooth Picks
Insert two tooth picks to the bottom of the bird to act as legs
Step 7: Cover
Cover each tooth pick with a piece of tin foil and shape with fingers
Step 8: Tail and Wings
Cut one heart shape piece of tin foil and place it on top of the body of the bird this will shape the wings and the tail
Step 9: Shape Foil
After you shape the foil it should look like this
Step 10: Cut Slices
Cut 4 one inch width slices of tin foil
Step 11: Twist
take each slice and twist to form the feet
Step 12: Feet
The is what it should look like for each foot
Step 13: Log
Take a piece of packing styrofoam
Step 14: Edges
Cut of the edges with a knife
Step 15: Round
Round off the off to shape like a log
Step 16: More Tin Foil
Get some tin foil
Step 17: Cover
Cover it with the tin foil
Step 18: Eyes
Get the black plastic and the pins
Step 19: Pin Eyes on Bird
Pin the plastic pieces on the birds head on each side.
Step 20: Insert Then Feet
Insert the tooth picks into the log and attach feet by wrapping them around the tooth pick and pin it with a pin
Step 21: Done
Done
Be the First to Share
    • Big and Small Contest
    • Game Design: Student Design Challenge
    • Make It Bridge
      Make It Bridge
    2 Comments
    diegolopez301
    diegolopez301
    Reply 2 years ago
    Thank you:)
