Introduction: Transplant a House Plant to Larger Pot (without Buying a Thing!)
*A Note:
I am not a gardener by any means. Any advice given is based on my own limited experience & minimal research. So take it with a grain of salt.
Step 1: Gather Supplies
1. a (recently purchased, in my case) house plant that's in need of a larger pot
2. an empty pickle jar (or any container of suitable size)
3. additional dirt (in my case, leftover potting soil* from a failed attempt at a previous house plant)
4. drainage; i.e.: something to put in the bottom of your new pot to keep water from collecting in the dirt around the roots.
5. newspaper or cut open plastic/garbage bag - something to collect the mess
6. pruning equipment (optional)
*potting soil would not be my first choice, I would've preferred a nutrient rich DIRT, but I don't have access
Step 2: Scrub a Dub
Make sure that your new 'pot' is clean & free from any residue.
Soak off any labels
Step 3: Build Your Base
Arrange your chosen method of Drainage in the bottom of the pot.
Now add a base layer of dirt.
(the amount you add depends on the size of your new container compared to the size of the plant's original container.)
Step 4: Add Your Plant & More Dirt
To remove your plant from it's original (plastic) pot; gently squeeze the sides a couple of times until you feel it loosen. Carefully hold the plant by it's base & pull the whole root system & dirt mass out together.
Then gently squeeze the root system to loosen it from it's compressed shape. Be careful & don't tear the roots.
Set the plant in the new pot & begin to add dirt around the root/dirt mass. Check it as you go & make sure the plant is sitting straight up & centered within the pot. Continue to add more dirt, gently pressing it into place with your fingers.
Step 5: Tidy Up!
If you've piled dirt anywhere on your plant other than the roots, remove it now.
I did some minimal pruning, just what was necessary for the plant to keep it's braided shape as it grows.
Never prune too much at once & always be careful not to 'shock' the plant's system with too much of any change.
Don't forget to sweep up too!
Step 6: Fancify, Hydrate & Admire!
I tied a piece of ribbon around the top of the jar, just to make it prettier ;)
Water your plant -after replanting, give your plant a little more water than you normally would, just to make sure all the new dirt is moistened.
Admire your handywork!
