Introduction: Trigger-Happy Fish Art
Fishing is a FUN and exciting sport because you literally PLAY with your food before it ever lands on your dining room table!
Now you can even play with fresh-caught fish (the skeleton, anyway) AFTER it's been eaten!
This pseudo-taxidermy Instructable will show you how easy it is to preserve and dry a fish skeleton... then turn that skeleton into a whimsical Work of ART!
The simple, straightforward technique is demonstrated with a Triggerfish but it can also be applied to many species of fish. Experiment with whatever fresh fish you catch.
Hang your fanciful Fish Art from the eaves of your porch or patio for a few months. When the odor dissipates, enjoy these colorful creations anywhere INSIDE your home!
Let's get started with a complete Project Overview for the the things you'll need, beginning with:
STEP 1: Clean and fillet
- A Triggerfish or?
- A sharp fillet knife
- Aluminum Foil
- A flat drying surface
- Rocks
- A cardboard box or plastic crate
- A dremel tool or drill with small bit
- Assorted acrylic paints
- Assorted paint brushes
- Clear gloss spray paint
- 2 Seashells (or buttons) for the eyes
- White Glue
- Glitter
- A Lure for hanging (optional)
- A Hanging cord, string or fishing line.
- A single earring or bead to hang from the tummy. (optional)
- Picture Gallery of my Triggerfish herd.
- More instructions on detailed painting.
Step 1: Fillet and Clean the Triggerfish
You'll need a Fish and a sharp fillet knife.
Before you start filleting, it's important for you to remember the fish needs a solid "Frame" of skin to hold it's shape. Don't cut through or compromise the "frame."
The second picture in this step illustrates (in white) where to cut.
The next several pictures demonstrate the actual filleting and cleaning of the stomach cavity. Like all fish-cleaning, it gets a little messy.... Guts Happen. ;-)
When your fish is filleted on both sides, clean out the stomach/gut cavity, cutting away all of the organ tissues. Work your fingers into the head cavity and pull out any residual tissue there also. The eyes are pretty slimy at this point. You can cut them out now or wait until the fish is dry.
Rinse the fillets well and refrigerate for dinner. ;-)
Rinse the fish skeleton well in cold water and pat dry with paper towels.
Proceed to Step 2-->
Step 2: Dry
You'll need:
Lay the Triggerfish carcass on top on the foil and prop the fins and tail with rocks so they are splayed open. (See pics)
Cover the entire fish with another separate sheet of foil. Do NOT seal it. Lay more rocks on the corners of the top layer of foil. **This allows air circulation and gives flies access to the fish (great for cleaning).
If you live in an area with neighborhood cats, you may need to take extra precautions. Place an old milk crate or empty cardboard box over the drying fish and weigh it down with rocks, a brick or whatever's handy.
Allow the fish to dry in position for 12-18 hours, then gently peel the fish up off the foil and flip it over. Put the rocks back into position on the fins and tail again. Allow it to continue drying another 12-18 hours.
By this time the fins and tail of the fish will be set. Remove all of the rocks and put the fish of a fresh sheet of foil. Cover as needed for protection and allow the fish to dry completely for 2-3 weeks, depending on how warm your area is.
*In case you forgot... the odor of the fish will remind you why good air circulation is important.;-) Don't even THINK of drying a fish in your house. 8-/
**Don't be alarmed at the swarm of flies on your drying fish! They are helping to clean it of excess flesh/meat. It's only temporary and it's just part of nature's process. Once the fish is dry, the flies won't be at all interested in it.
- A table (or any flat surface) located in a secure, WARM, dry area with *good air circulation
- Aluminum foil
- Assorted rocks
- A crate or cardboard box to cover and protect the fish from animals.
Step 3: Drill the Holes and Paint
You'll need:
Use the white acylic to paint the entire fish, including what you can reach in the cavity.
Using a dremel, drill a hole at the top of the fish for hanging. If you're going to hang a bead or earring from the tummy, WAIT and do this after the fish is hanging so you can gauge where to drill the hole.
When the white acrylic paint has dried, it's time for you to start the decorative painting. Have FUN!!! Be as creative and colorful as you desire!!!
The Eyeballs: Pre-paint a couple of seashells (or buttons) and glue them into place as pictured.
Once you've finished your Fish Masterpiece (and the paint and glue have dried) give the Fish a few coats of clear gloss spray paint and a dusting of glitter.
Your Fish Art is ready to hang on display. You can hang it using a Lure or hook with heavy fishing line or just tie it with a cord.
If you're adding a dangling bead or earring to accent the tummy cavity, hang the fish up first so you can determine where to drill the hole for this.
I've painted more than a dozen fish in all sorts of fun and crazy designs. (They make wonderful gifts!)
Step 4 includes a picture Gallery to give you some ideas.
ALSO: If you'd like to paint an intricate scene on the sides of your fish, measure and cut out a few sheets of paper to glue onto the ribcage. See the last few pictures in Step 4 for a visual. ;-)
- White Glue
- Glitter
- A cord, string or fishing line for hanging.
Step 4: Gallery of Triggerfish
Here's MY colorful herd of Triggerfish. They hang outside on my bedroom balcony. They twist, float and sway with the wind in beautiful, colorful, perfect unison! ;-)
There's also a multi-picture demonstration of gluing white paper to the sides of the fish to paint more precise and intricate designs.
Thanks for visiting my Ible!
I hope you'll have fun and feel inspired to create and share your own unique Fish Art!
