Introduction: Ultimate Marshmallow Gun/Shooter
A marshmallow gun that can fire fully automatic, or use a "bolt-action" method to reload quickly. Fires Model Magic pellets for increased efficiency and less mess.
Step 1: Ammunition
For this gun I use model magic pellets(you can use marshmallows, but this is more efficient and doesn't make a sticky mess).
There are two types of pellet that I use:
Ball: This is a small made of model magic that is slightly smaller that the diameter of the barrel. It has to be small enough to roll easily down the barrel, but big enough to keep air from flowing past too easily.
Bullet: This is a bullet shaped pellet that is about the same size as the barrel so that it wedges in. It needs to be between 3/4 of an inch and an inch long(any longer and it will go end over end in the air and decrease accuracy and range, any shorter and it will fip in the barrel and jam). It is better with a pointed end.
Don't use standard modeling clay, as it is too heavy and it will stick to the barrel. You can use types of clay that harden, but they are very hard and dangerous, so be careful.
Try experimenting with other shapes and let me know if you find a good one.
Step 2: Pieces Needed
You will need 1/2 inch CPVC pipe(not PVC as it is bigger than CPVC). It is tan in color and usually comes in 10' lengths. You won't need 10' for this gun, but if you want to add parts or make new guns it is good to have a lot.
You need the following lengths:
1 15-16" piece
2 6-8" pieces
2 5-6" pieces
You will need 1/2 inch CPVC couplings for this gun.
This gun needs 2 T couplings and 2 end caps, but I suggest buying some extras. It is good to have extra Ts and endcaps, and 90 and 45 degree elbows and straight couplings are fun to experiment with.
The last needed item is Model Magic for ammo.
Step 3: "Bolt-Action"
This is the most innovative part of the gun. People have been searching for an effective way to reload a marshmallow gun without jamming, and this is it!
The secret is that one of the 5-6 inch pieces of pipe has a cut in it 3/4 of an inch from the end almost to the bottom, and across to the end. This leaves a small ledge that will block the hole for the back handle/magazine when the handle is down. This pipe will not fit into the T properly, so you will need to whittle the bottom of the ledge down to fit it in.
The way that this works is fairly simple. when the handle, which is full of balls, is turned upward it is clear of the ledge, and a ball falls into the barrel. When the handle is turned back down the ledge isolates 1 or 2 balls in the barrel and prevents them from falling back into the handle. This system will not jam easily because the ammo is round and isn't sticky, and the constant motion of the handle moves the ammo around.
Step 4: Barrel Assembly
Put the non cut 5-6" piece into one end of a T. Put the 5-6" piece with the ledge into the other end of the same T, with the ledge inside. Put another T on this 5-6 inch piece and put the 15-16" barrel into this T. The barrel is complete.
Step 5: Handles/Magazines
Put the 2 end caps onto one end of each 6-8 inch piece. Put these into the bottom of the Ts. The gun is now complete.
The front handle can be filled with balls for automatic fire, and the back handle can be filled for bolt-action fire.
Step 6: Fire!
To fire with bolt action turn the loaded back handle to the top of the gun, and when you hear a ball enter the barrel, flip it back down. If you did this right there should be 1 or 2 balls in the barrel. Blow into the mouthpiece to fire.
To fire automatically flip the front handle upside down and leave it blow hard to make sure all come out at full speed.
When using bullet shaped pellets you cannot put them straight in the back of the gun, because it will get stuck on the bolt action piece. You can either separate the handle at the T and load there, or turn the the bolt action piece around so that the ledge is in the front T. These pellets go farther and are more accurate than balls, but are a pain to make and to reload, so use sparingly.
Be careful and have fun!
