Ultimate Weed Removal Tool
Intro: Ultimate Weed Removal Tool
I was tired of crawling through the lawn on my hands and knees using a hand-held weeding tool because I DO NOT like using chemicals on the lawn with pets, kids, and wildlife also being on it. I saw a similar tool at the BigBox store with a telescoping handle that would get me off the ground, but they wanted $11 for it. I knew there was a better (and cheaper) way. I was inspired by Clint's Dandy Digger! I had part of an old crib frame that would provide the angle iron, but I wasn't sure I could weld the foot peg on just like they did for the dandy digger. After starting to cut the extra parts off of the frame I saw the answer...
Follow along as I create an awesome weeder that can be used standing up.
***This instructable involves power tools (welder, reciprocating saw, drill, & grinder). Please make sure you wear safety gear and know how to use a power tool before you attempt this instructable.***
STEP 1: Find Materials
I had an old crib frame in the garage and thought it would be perfect to supply the angle iron for this project.
STEP 2: Cut to Size
I cut the end off of the frame that had a 90* bracket welded to it with a reciprocating saw and 3-in-1 oil to cool things down and preserve the blade. This bracket ends up being reused.
STEP 3: Sharpen Tool End
In order for this tool to dig easily into the ground you need to cut an angle on one end of the angle iron. I attempted to cut a 45* angle but really I just eye-balled it. You just need it to be "pointy" enough to penetrate the ground but not so steep to make grabbing the roots difficult. I used the reciprocating saw again for this cut but then finished it with a grinder equipped with a cut off wheel (the grinder is MESSY but much easier and faster to make cuts with).
STEP 4: Grind Paint Off
I used the grinder to remove paint on the angle iron and bracket. I ground the paint off from about 4" from the point to 7" from the point, and all surfaces to be welded on the bracket.
STEP 5: Clamp Together and Weld
I used vice grips to hold the to parts together with the bottom of the bracket about 4" up from the pointed end. Using a MIG welder I welded around on each side (sorry for the lack of pictures of this process).
STEP 6: Attach Handle
I just happened to have an old hockey stick in the garage but I am sure with some ingenuity a round handle could also be used. I clamped the handle to the weeder with a C-Clamp and quick-grip clamp then pre-drilled the holes in the metal (again with 3-in-1 oil) and using self tapping screws attached the handle to the weeder.
STEP 7: Take It for a Spin
Before getting too far I tried it out on the weeds next to the garage. Place the tool in the ground with hand power (or use the foot peg if the ground is hard/rocky), pry back and wait for the *pop* of the root.
STEP 8: Finishing Touches
The only paint I had around was white (i would have preferred black or something florescent) but anything to prevent rust is necessary after all the cutting, grinding, and welding.
24 Comments
_diyMATT 10 years ago
MichaelP19 8 years ago
Boiling water certainly does do the job. I've invented a new weed killing sprayer using hot water and acetic acid (mild solution - about like lemonade). If you have the time, please check it out and tell me what you think. www.gardenhotshot.com
Thanks,
Michael
DIY-Guy 9 years ago
Boiling water on dandilions scalds the leaves, but will the deep taproot be killed? I spent a lot of money heating water and pouring it out once and was not sure it the cost return ratio was worth it; compared to the time for pulling (at zero cost). Can you give more details please? Thank you!
_diyMATT 9 years ago
DIY-Guy 9 years ago
Thank you. Does it take a flooding, water sits on the root in a boiling puddle for 60 seconds, or what? Application specifics might be making all the difference for you. :)
I just boil water in a kettle and go out and dribble a bit on the base. 1/4 cup? A bit more if it's mega big but honeslty not much. You can see the root die in under a day.
sunshiine 10 years ago
sunshiine
antioch 10 years ago
calskin 10 years ago
No disrespect to the OP though. This is a cool tool which doesn't have to be used on any medicinal plants.
jlawrence11 10 years ago
brianadkison 10 years ago
vincent7520 10 years ago
Any link by chance ?
ChrissTheChiller 10 years ago
have a look here:
http://www.wikihow.com/Make-Dandelion-Wine
Thank you !
lhsk8r 10 years ago
indianajoel 10 years ago
