Introduction: Winning Tic-tac-toe Strategies
Everyone loves the simple game of tic-tac-toe, but it seems like a random game. Actually, its not!
It seems that many disputes can be solved by a simple game...
Now you can win the next tic-tac-toe-off by looking at these 4 easy strategies!
**EDIT** Thanks to kelseymh for pointing this out- you can only win if your opponent makes a mistake. If both players make the best move they can, the game will tie
Step 1: The Middle Block
Ok, so there are 8 possible ways to win. Here they are in the pic below...
I also labeled each block with a number to make reference easier.
Did you notice that exactly half (4) of the combinations use the block 5? Most people, if starting, will take that block. They figure it gives them the best chance of winning, because it has more possibilities than, say, taking block 1, where you only have 3 possible paths.
So, by taking block 1 you theoretically have the best chance. But any path using block 1 is very easy to stop.
Step 2: Strategy 1
If you take three corners, you have three options. This is my favorite strategy =) and also one of the best
Step 3: Strategy 2
Now I know I said taking the center was bad, but not always. If you use this option make sure to take block 5 first, because thats what your opponent will most likely want.
This gives 3 paths to take, but since you need to pick two that are next to each oher to set this up, your opponent will most likely block one of your options.
Step 4: Strategies 3+4
These next two are basically the same but flipped. They aren't as good as the first two, because you only get two paths.
I reccomend taking blocks 4 and 8 first because it makes your move less obvious. But if you do that, the other player may take 5.
Step 5: Have Fun!
Now go amaze people with your winner-ness :D
21 Comments
1 year ago
I love this app! It is always really fun.
Reply 1 year ago
What app?
2 years ago
It`s great. Works every time.
3 years ago
Nice write-up, but "Strategies 3+4" are not good - you can lose the game by following them. If you start by taking 4, your opponent can respond by taking 1. Now if you take 8 you will lose the game after your opponent takes 3. Take a look at a more detailed explanation at https://www.paperandpencilgames.com/2019/04/tic-tac-toe-trap.html
5 years ago
Thanks for the tic tac toe tips!
6 years ago
Well you can win by double trapping them.I did it and I won lots of times :)
10 years ago on Introduction
If you start this is an easy win X in center O in corner, then X in diagonal opposite (i.e. upper left lower right). Then if O goes right next the first O then X blocks it. Now O has 2 choices to block X's places, but only place to go. Now, X wins!!!
11 years ago on Step 5
Thanks! Now, to figure out how to win rock paper scissors every time...
here you go.
Reply 10 years ago on Step 5
wow....
aweeeesome! I love the Mario Kart reference xDD
Reply 11 years ago on Introduction
i know how to
ok first do a regular round of rock paper scissors then call a break after every round if the opponent was scissors and they where rock they would think you would do paper because you would think to do paper so they would do scissors and then you would do rock and win
or you could just do the double win
XIXIX
OIXIO
OIXIO
I do not quite understand, my English is poor. My strategy is, taking the center, place the second piece so as to force the opponent to align the second piece with his first, as if he were about to win. Then I lock him with my third piece, and it has no alternative of winning.
This is slightly more compact: http://xkcd.com/832/. You may or may not know that if both players make optimal moves every time, the game will always end in a draw. This was proven long ago.
So what you mean is if both players are trying to use the same "winning" strategy, it will end in a draw? I get that now, thanks for the help! I found out that when I told my mom what the move I used was, the next time I tried using it she tried to block that move. Because she tried to block that move, I won by another move.,,this is so crazy.
Yes, if both players make the best move they can, you can prove that the game will end in a draw. Tic-tac-toe is simple enough that you can write down every single possible move (that's what the cartoon shows). Every winning game is due to one player or the other making a mistake.
Thanks for the help =)
You're welcome! Tic-tac-toe is a very good problem to learn game theory. It is simple enough that you can work out the solution by hand (the Wikipedia article gives you the basic outline), and you can relate it to much more complicated games and theories.
I havent yet, I want to though.
