Introduction: XW30K 8-1/2 Cm Shot Shifle
this is the one, the only, the shifle. in case you dont already know, the shifle is a pump- action shotgun/ rifle, with the ability to shoot 50 rounds in under a minute. this gun shoots about 30 feet, but shotguns arent usually used for long-range combat, but rather for close-range combat.
If you need help building some of the parts, you will find Ipod Killer's sniper here.
stats:
barrel style: ipod killer's drop-in type
magazine style: ipod killer's 5,11, or 50 (recomended) shot magazines
trigger system: backwards pull-release system (by ipod killer, but mine is backwards)
pump system: sliding wheel and pully system
ammunition type: yellow rods
handle type: ipod killer's sniper handle- shortened
slider type: one slot gray connector to gray rod slide
firing pin style: large rod -strengthened black- and blue extender connected withstring spindle.
stats:
Step 1: The Sliding Handle
1. make 24 of these
2. now put all 24 onto the gray rod like so
3. attach the string like this, leaving about 2 inches out
Step 2: Secure the String
1. pull the string to the other side and wrap tightly around the rest of the gray rod a few times
2. place the string like this
3. this is the other side of the string placement in step 3
4. put the string trough this part of the connector
5. push a gray rod into it like this to hold the string in place
6. another pic of this
7. to finish, put another gray rod through the other side
Step 3: The Barrel
this is exactly the same barrel as ipod killer's sniper rifle with one exeption-two pieces are taken away. refer to the pictures.
Step 4: Barrel Continued
this is a pretty easy step to follow
Step 5: Add Extras to the Sliding Handle
hi
Step 6: Making and Adding the Slide
hi, me again
Step 7: Connections
does this make enough sense?
Step 8: The Firing Pin Slider
this is the firing pin slider
Step 9: The Trigger Thing
simply make the trigger, by the way, there are 10 light blue washers
Step 10: Make Connections
Step 11: Firing Pin
Step 12: Handle
1. the back end of the gun that you will make next
2-6. steps progressing through the handle construction
Step 13: Trigger
construct the trigger
Step 14: Rear Body
start the rear body
Step 15: Top and Pully Housing
Step 16: Adding the End of the String to the Equasion
1. push the string through the front and under the wheels
2. when you push it through the front be sure top push it through the orange connecter
3. out the other side
4. over the top and through the orange connector again
Step 17: Just More Pieces
self explanetory
Step 18: Connect the Handle
pay attention to the gray connector in pic 3
Step 19: Connect the Handle to the Slide
connect like shown
Step 20: The Final String Wrapping
1. the firing pin pushed all the way in
2. pull the firing pin out about this far before starting to wrap the string
3. wrap the string tightlyaround like shown
4. take the top part off and put the remaining part of the string into here
5. replace the rod back on like this
Step 21: Rubber Bands
1. put on 2-4 thick rubber bands on
2. there should be about this much space in between the spacers and the end of the pin
Step 22: Build the Backbone
i find that this is very easy to build according to the pictures
Step 23: Attaching the Backbone
Step 24: An Extra Rubber Band That I Just Remembered
Step 25: Side Panels
enter longer description for this step
Step 26: Magazine
1. this is ipod killer's 50 rod magazine, you can go to his sniper instructable to find out how to build the 5, 11, or 50 rod magazines, although i prefer the 50 rod magazine
2. the gun completed
3. the ammo
3. the ammo
Step 27: Extras
the safety mechanism
1. safety off
2. safety on
1. safety off
2. safety on
Step 28: String Placement
this step is just in case youre having trouble with the sring. the string should run down the middle of the gun, never on the outside. the purple is the string.
The string should be about 4 feet long.
