Introduction: An Even "cooler" LED Grow Light
hello everyone,
please support & share our mission;igg.me/at/smartplants
today we will be putting together yet another LED grow light. a much cooler one..
cooling down grow lights are still the biggest issue, whether HPS, CFL or LEDs. most of the space usually goes towards this problem with either of these system. most of the cost also is created towards the solution, fans. lots of them..
LED grow lights have already proven themselves easier to cool down compared to other methods. my previous design; https://www.instructables.com/id/LED-Grow-Light-4/ had to use fans to cool itself, due to the lack of a proper heatsink.
This time however I decided to use proper heatsinks, making the project fanless - also freeing up an outlet.!! new design is also more powerful, 12W to 16W. capable upto 20W using the same amount of space.. a huge improvement.
ingredients;
- 3x heatsink; http://www.ebay.com/itm/201271515239?_trksid=p2060...
- 4x 660nm 1W; http://www.ebay.com/itm/10pcs-1W-Deep-Red-660nm-LE...
- 4x cool white 1W; http://www.ebay.com/itm/1W-3W-High-Power-cool-warm...
- 4x warm white leds 1W; http://www.ebay.com/itm/1W-3W-High-Power-cool-warm...
- 1x led driver; http://www.ebay.com/itm/Mean-Well-MW-9-36V-350mA-1...
- 1x metal sheet; http://www.homedepot.com/p/MD-Building-Products-12...
- 1x ac cable; http://www.ebay.com/itm/US-2-Prong-Port-AC-Power-C...
- 1x switch (optional); http://www.ebay.com/itm/5Pcs-2-Pin-Snap-in-On-Off-...
this new design is 16W, ~34V @350mA. it is $10 to operate 18hrs/day x365 days. and even less since there are no fans used anymore.
let's build>
Step 1: Measure
i need to be able to hang the light, and adjust its height as needed.
for this we need to make a frame first. I cut a piece of thin metal sheet using a drill and rotary cutter.
you could "glue" the heatsinks side by side using metal epoxy for your specific design. I could use a little distance between each light source..
i designed the cuttings in such a way that we should be left with nice little holders in place.
Step 2: Cut
first i used the drill to make lots of tiny holes along the cut lines, in pursuit of less rotary cutter time.. you can go either way for a cleaner cut.
after you cut the lines, bend the little flaps upwards using plyers.
it is going to be a tight fit, slowly try to place the heatsinks into the holes. make sure to cut less at first if you arent sure about the dimensions, you can always go back and cut more. much easier to fix..
Step 3: First Trial
also drill 4 holes for the carrier wire.
attach some garden wire to each hole and hang where needed..
Step 4: Wiring
here is the wiring diagram of the LEDs, solder everything in series.
using very little thermal glue place each led on the heatsinks. these heatsinks are supposed to work with 5x 1W LEDs. 24/7 x365days ON.
however I chose to use 4W/heatsink to get better cooling, and left the middle of each heatsink empty as I may upgrade to 5W/heatsink in the future.
there are many heatsink options out there, you can get
single 1W heatsink; http://www.ebay.com/itm/5pcs-1W-Watt-LED-Aluminium...
or upto +20W heatsink; http://www.ebay.com/itm/Aluminum-HeatSink-Cooler-C...
using them side by side etc, one can design a very effective and sleek grow light.
Step 5: Conclusion
the heatsinks do get warm, as i leave them on for long periods of time.. i am yet to test the actual temperature with an IR thermometer. will update here once done.!
i am in the process of updating box1; https://www.instructables.com/id/box1/step10 - i need a simpler, a more sleek look. allowing more space left for what really matters, plant growth.
I will be making more prototypes using other styles of heatsinks available as well, subscribe to stay updated. I also am going to try to use peltier thermoelectric cooler/heaters.
love & peace
5 People Made This Project!
- RobinP55 made it!
- JakubB10 made it!
- JakubB10 made it!
- tiunkabouter made it!
See 1 More
47 Comments
5 years ago
Hi Akin! Great Work , thank you!
I failed at buying the right led driver, instead I bought 18V - 700mA.
How could I use this driver withe 1w leds ? I tried looking online but did not understand how to do it :(
Anyway good luck with your projects and keep up the good work!
Reply 5 years ago
hello, sorry for the late response :/
1w led = 3.5V @350mA since you are using a 700mA you have to add the 1Ws in parallel to reach 700mA. and since its 18V, you also need to add 5 of them in series. (18/3.5=5)
so what you need to do is add 5 1W leds in series, and make 2 of these. then connect these 2 strips together in parallel. which will equal to 18V 700mA :) 10LEDs total, 10W, equal to 90W incandescent.. pretty strong tiny light source.
here is a quick diagram. this is electricity 101. if you add in parallel, current mA goes up, if you add in series, voltage goes up. hope this helps
Reply 3 years ago
Hey sorry for the even later response,
but thank you so much for answering this one and posting your builds!
Much Love, Kuffy
6 years ago
Is it possible to create a 100W light?
Reply 6 years ago
yes it is possible. you have 2 options for a 100W light.
1. http://www.ebay.com/itm/10W-20W-30W-50W-100W-LED-F... ready to use with regular AC plug. no fan or heatsink required due to design. also comes with reflector and attachment system. this is a VERY good light.. get warm white and cool white..
2. make your own.
- light; http://www.ebay.com/itm/100W-LED-SMD-Chip-Bulbs-Wi...
- heatsink; http://www.ebay.com/itm/Heatsink-Cooler-Fan-DC12V-...
since the final price of either option is very close, i would rather choose option 1 as it will be much more durable and tested. however those only come in cool white and warm white. to add more spectrum you can use these chips and make your own; http://www.ebay.com/itm/100W-50W-30W-20W-10W-380NM...
the problem over 3W LEDs is that now you are talking about serious cooling issues. you have to have the rightsize heatsink and most likely a fan with a DIY light. they will both work great.!! give it a try
Reply 6 years ago
Awesome. Thank you. I am going to build this one first and then move on to that. Would it be possible to wire x10 10W in series and make 5 rows of these totaling to 500W? I am in a winter crop class, and we have these 500W full spectrum light bars that I really want to see if I can't design and build my own for cheaper!
Reply 6 years ago
yep, you got the idea.. LEDs have surpassed any other light source out there years ago. it will be much better than what you have right now.!! give it a try and document with picx.
thank you for your interest
6 years ago
Just ordered all the parts! Going to build this soon. Will post some pics. Thank you for this excellent guide.
Reply 6 years ago
great news.!! remember to document it with pictures.
6 years ago
Hi I did my own version of this project and used these LED's
2 X 430
2 X 660
2 X cool white
2 X warm white
the LEDs are connected to an LED driver and my power source is 3 X 9v batteries. I also have a two pronged switch connected to the batteries and to the LED driver except the LEDs are not lighting up. Any suggestions?
Reply 6 years ago
can you show me a picture of your LED driver. i believe what is happening is that your driver is AC to DC driver. and you are trying to power it up with a DC battery. this option will work but you will need the right driver. this is why I need to know what driver you are using. can you please share a link/picture.
you also need to explain your wiring. are they in series, the batteries and the lights. i need more info
7 years ago
I am inspired by your work & have decided to get into this.
Went to karakoy (yes), bought 30 LED's, 30 star bases, 2 drivers & 6 heatsinks. I'm pumped & ready to go...EXCEPT the thermal glue.
First, they are so expensive in so little packages (Even more expensive than deep red LED's) do you know a good place to buy in Istanbul by any chance?
Second, what would be the alternative to thermal glue? I read online that some people mix superglue with classic thermal paste, is it a viable solution? what would you advise?
lastly, some of the heatsinks have a cheap looking thermal sticker on it, the thickness of the sticker must be around 0.1mm and doesn't cover all the star-bases (as shown in the picture)
Am I being too cautious? or should I stick to the safest path and spend extra and buy the glue?
thanks a lot.
Reply 7 years ago
technically you do not need thermal paste. you can just use nuts&bolts; http://www.ledsupply.com/images/tslot-animation-cr...
but this way you will need to drill holes. as long as you have a clean wide surface area for the heat transfer everything will be fine. are your LEDs 1W or 3W.?
also it looks like you have led beads and little base stars separately. you will need thermal paste for under there however.!! all you need is very little, like extremely little, less is better. put a VERY tiny thermal paste and push it down hard while turning the light left and right to spread it out evenly. use very little, allow it to dry overnight.!!
you can find more info and ideas here; https://www.instructables.com/id/LED-lights-1/
let me know how it turns out.!!
7 years ago on Introduction
Great tutorial. I would like to build this but have two questions first:
Is this setup suitable for growing herbs from seeds? (Basil, Thyme etc)
And, do I need to make any adjustments with the electronics to ensure it works when attached to the mains (I live int he UK)?
Thanks!
Reply 7 years ago
wow i can't believe that i have missed this comment.. did you get it sorted out.? so sorry,
yes this setup is suitable for herbs but honestly you can grow anything under this light. i currently have a citrus tree that is 3yrs old - from seed
nope, the led driver i use is 100-240AC universal, you can use it right away safely.
Reply 7 years ago
Hello, i have a question.
I would like to make this light from 4 heatsinks, 5 LEDs each 1W.
How many of each LED colour do i need to have the best results? (Basil, lettuce, thyme maybe some flowers), and how powerful of a driver?
Reply 7 years ago
how big is your grow area.?
Reply 7 years ago
i have 3-4 pots with max diameter of 10.5 cm. I grow in this thing from swedish furniture manufacture
I want to make it from 4 heatinks, so i can bend in the middle and mount at the roof of this thingy, so it looks nice and as clean as possible
http://www.ikea.com/pl/pl/catalog/products/4025759...
Reply 7 years ago
pretty much something like this you have in mind. each of these plants have a heatsink with 5x3W LEDs on them. user tiunkabouter below shared his work.
if you use 1W leds then you won't need fans, and it will be a low profile light. there are many ways of going about it. i can draw you a schematics if you want..
you would need 1x 40V @700mA LED driver and can use 8x warm white, 8x cool white, 4x 660nm red. each light would have 2x warm, 2x cool and 1x red. you would connect 2 of these light together in series. and then 2 sets in parallel to a single driver. or leave them seperate with their own LED driver.
i can draw you a wiring diagram once i get home. i wasn't able to open the ikea link btw
Reply 7 years ago
i would be thankful for the diagram and wiring schematic. Thank you for your time
