Compressed Air Rockets
48,206
124
30
Introduction: Compressed Air Rockets
About: Build.Share.Destroy.Repeat. Follow me and try a few of my projects for yourself!
When I was at the Bay Area Maker Faire earlier this year I saw a display that had a compressed air paper rocket launcher. Kids would make their own paper rockets, load them onto a launching tube and fire them into the sky. I thought it was pretty cool, but wanted something more dangerous different.
So, how do you make compressed air rockets better? By making exploding compressed air paper rockets!!
Using simple Chinatown fireworks, combined with an elastic deployment system to eject a small toy parachute action figure, I designed a rocket which jettisons the parachute man from altitude. I made 3 test rockets which were designed to test and calibrate the compressed air launcher and 6 live rockets which were intended to test the theory and intent of my design. Unfortunately, it didn't quite turn out the way it was supposed to. All 6 live rockets exploded, melted or malfunctioned and no parachute men were successfully deployed.
So, instead of this being a how-to it's more of a how-not-to. Check out the video where all the spectacular failures are captured:
Obviously working with fireworks, compressed air, power tools and rockets is dangerous business. Use common sense and work within your ability.
Enough talk, let's explode some rockets!
Step 1: Tools + Materials
tools
  • hacksaw
  • wood saw
  • drill + bits (various sizes, wood bits)
  • scissors
  • hobby knife
  • PVC glue
  • lighter
  • masking tape
  • bicycle pump
materials
  • pvc pipe
    • 1 x 2" diameter pipe (roughly 24" long)
    • 1 x 2" cap
    • 1 x 2" diam to 1.5" diam. bushing
    • 2 x 1" threaded coupler
    • 1 x 1" diameter pipe (roughly 24" long)
  • launch platform
    • scrap wood uprights
    • scrap 1/4" plywood base
    • scrap 2x4" for blocking
    • scrap 2x4" for launcher stabilizer
  • sprinkler valve (1" ingress/egress)
  • compressed air-gun trigger
  • Schrader valve (inner tube valve)
  • paper
  • cardboard / cardstock
  • elastic bands
  • threaded rod + wingnut
  • cable ties
Step 2: Launcher - Overview
All compressed air rocket launchers work under the principle of rapidly displacing air to launch a projectile. Air can be pressurized in a chamber and then deployed by means of a trigger or stored in a bladder and squeezed to be released, these are active and passive systems.
Active, or pressurized assemblies are capable of producing some spectacular results due to the high pressure able to be stored in the chamber. Passive systems like stomp rockets reply on the pressure created when the air bladder is squeezed. This project focuses on the former.
The setup of this pressurized air launcher is simple:
  • air is supplied through a bicycle pump attached to the intake nipple
  • air is held in the pressure chamber until released by trigger
  • trigger is attached to a modified sprinkler valve (pilot valve)
  • when trigger is activated air is released through the exhaust
Keen observers of Instructables.com may recognize this canon as Fungus Amungus' Christmas canon.
This is the same canon but adapted to fit on a launching pad. And this version shoots exploding rockets, not confetti.
Step 3: Launcher - Detail
Chamber:
This canon was made with about 28" of 2" PVC pipe as the chamber. Cut your 2" pipe to length and glue on the 2" cap to one of the ends.
On the other end, glue on the 2" to 1" bushing. Then, cut a 4-6" length of 1" PVC and glue that into the bushing.
Finally, glue the 1" threaded coupler onto the 1" pipe attached to the bushing.
Set chamber assembly aside for 24 hours until glue has cured.
One set, drill an opening in the cap for the schrader valve. Tap the opening and wrap the valve in teflon tape and screw into opening.
Sprinkler Valve:
I did not perform the modifications to this valve. It appears that the valve has had the electronic solenoid removed and replaced with the handle and trigger for a compressed air nozzle. The trigger is threaded and fits directly into the place where the solenoid trigger was. Replacing the electronic portion with a simple mechanical action.
The valve is 1" female threaded on both ends.
Exhaust:
Cut a length of 12-14" of 1" PCV pipe, then glue the threaded couple to one end. Set aside to dry.
Step 4: Rocket Assembly - Fusalage
Time to make our rockets!
Take an A4 (8.5x11") sheet of paper and roll it lengthwise, using a 1" PCV pipe as our frame. When the paper has been completely rolled tape the length with masking tape.
Next, cover the top of the paper with a cardboard or cardstock circle roughly the same size as the pipe (1" diameter). Then secure it in place using several layers of masking tape. The masking tape allows the rocket to withstand the pressure when the PVC pipe is filled with air, and the cardstock provides a rigid flat base for the rest of the payload to be build upon.
Step 5: Rocket Assembly - Payload
The payload is the most tricky part of the assembly, and errors here are probably what brought my project to failure.
lower assembly (charge):
After the fuselage has been completed a short cylinder of cardstock was installed on top of the bottom deck previously installed. The cylinder was secured with plenty of masking tape, and a firework was installed inside.
Notches were made in two places on the top portion of the cylinder after it's been installed; one at the location where the firework will explode/emit flame and another off to the side which will allow the fuse to pass through and be lit once the assembly is closed.
With the firework installed, another circle of cardstock was covered in aluminum foil and installed over the cylinder opening. More masking tape was used to secure the charge in place, ensuring that the notched openings created earlier weren't covered.
upper assembly (parachute man):
Another longer cardstock cylinder was made and attached to the lower assembly in just one small area using masking tape, making the top cylinder a hinged. This hinge will allow the payload to open when ignited and the brave parachute soldier will be deployed. Well, that was the idea. The top of the upper assembly was capped with another circle of cardstock, then a parachute soldier was inserted into the assembly. Close the upper assembly and use a single strip of masking tape over the notch made earlier for the firework explosion point.
A cone of paper was added to the top after the payload was finished assembly.
elastic mechanism:
To allow the upper assembly to flap open when the masking tape strap was severed an elastic was used. Cut a rubber band and fix one end to the upper assembly, pull taught and fix the other end to the base of the fuselage. I used masking tape to secure the elastic in place.
Step 6: Launch Platform
Since I was going to be filming, lighting fireworks and pulling the compressed air trigger I needed a platform to hold the launcher.
I made this launch platform in less than a hour with scrap wood hanging around the shop. This platform is made from a 12"x12"x1/2" sheet of plywood, a drawer face which measured 6"x48"x1/2", and some 2"x4" off-cuts of various lengths.
A threaded rod was installed near the top and through a 2"x4" which allows the launcher to be directed at an angle. you know, in case I wanted to launch exploding rockets at the neighbours and not just straight up.
Holes were drilled into the top movable platform which the launcher will be strapped to with cable ties.
Step 7: Launch!
With the assembly done it's time to test the rockets out.
You should probably launch someplace that is wide-open, has no people or buildings nearby which could be damaged and should be definitely be undertaken by someone who knows what they are doing. Not heeding my own advice I launched from the roof of the Instructables.com lab in downtown San Francisco.
Here's a few animated GIF's from rockets #1-3 shown from a different angle than the video shown earlier.
Step 8: Results (with Bonus Firework Testing Footage)
My measure of success for this project was successful deployment of the parachute soldier at altitude. To that end, this project did not work as intended. However it was loads of fun to make and any project I can walk away from with all my fingers should be seen as a positive learning experience.
Here's the video of testing the different variations of the firework I used. The first iteration was a control with each variant after modified the firework slightly so it would behave differently.
A special thanks to kazmatazwho was my diligent launch Commander, took amazing photos and was great support.
Did you make your own version of compressed air rockets? Place a picture of your version of this project in the comments below.
That's it, get outside and fire off some rockets.
Be safe and have fun!
Launch It! Challenge
Make It Move Challenge
Celestron Space Challenge
Be the First to Share
    • For the Home Contest
    • Make It Bridge
      Make It Bridge
    • Game Design: Student Design Challenge
    30 Comments
    Jessetech17
    Jessetech17
    Question 4 years ago on Step 1
    Can i still make the rocket with the rockets
    Is this for beginners? I want a rocket for beginners. Also I want a rocket that flies very high. Do you know how to make a rocket that flies extremely high for beginners?
    THX in advance
    mikeasaurus
    mikeasaurus
    This project is pretty good for beginners, but there's also this!
    Luziviech
    Luziviech
    Reply 6 years ago
    when i was a boy, i had a friend who used rockets from a rocket model shop; once showed me a rocket engine that looked and worked like cracker, round piece with a match cord. I then found out that these paperback rockets can even be bought as kits with several stages of ignition and cost around 30 bucks upwards, but come with a stand - if i was about shootin a rocket into the atmosphere with a cam as payload for example, i'd probably use something like them.
    Luziviech
    Luziviech
    6 years ago
    actually, i was lookin for something similar and imo your ible is great. But as parachutes don't work, why don't you take glitter as payload?
    mikeasaurus
    mikeasaurus
    Reply 6 years ago
    That's an excellent idea! Next time I make compressed air rockets, this is what I am doing. If you try it out, please share some pictures here :) I'd love to know how it looks.
    Luziviech
    Luziviech
    Reply 6 years ago
    uh, well, basically i would. We had tons of glitter on the last juggling convention and i told the boss of my idea yesterday, but he said no as, this year after the con, he got into trouble with the technicians.
    As well, I always wanted to do something with rockets or a crossbow (like the ipad7-ible) on a festival in hungary as well as the workshop area where i'm working is on top of a hill and the stages in the valley, but 1. that won't happen before next year, 2. i'd need a secure plan and ask for permission. But i'm quite pessimist about a glitter-payload as the whole area is grassland for a sheep flock. But on the other hand i also found an ible yesterday about edible glitter, which basically is colored baked sugar - i'm just not sure, if it's shiny enough for a rocket.
    But maybe you find out?
    mikeasaurus
    mikeasaurus
    Reply 6 years ago
    Glitter is something you never want to ask permission for because the answer is always no- better to beg forgiveness :)
    Also, the idea of sheep eating glitter and producing sparkly poop is something worth exploring.
    Luziviech
    Luziviech
    Reply 6 years ago
    certainly funny, but the plastic got sharp edges and can cut your guts inside afaik. And a shepherd who owns the festival area and knows me as an artist working on his festival, i don't want to piss him off this way.
    And today i remembered that someone once told me that if you throw a cent coin fro Cologne cathedral and it hits straightwards someone standing in front of the cathedral with its edge, it can break through the head-bone. Thinking about Newton and so on - and how would that be with sugar crystals and is it possible to grind sugar that fine that it rather floats down? And what about powdered sugar? D'uh, i have to find me a cracker and find out...
    marshall.hird
    so i made on and the valve seems to release very slow. Batteries are good. anyone
    know what the problem may be???
    mikeasaurus
    mikeasaurus
    The sprinkler valve should have instantaneous release of all stored air. If you are getting a slow release are you using the right valve?
    There are no batteries with this system.
    ilpug
    ilpug
    11 years ago on Introduction
    awesome, i saw that very same exhibit at that very same maker faire and thought something along these lines. well done. couple things though:
    -slightly larger images of the payload assembly might help
    -Did you do this on top of a building? in a city? next to skyscrapers? do you know how illegal and dangerous that is? one of these could have easily blown out one of those shiny windows. im not sure what psi you are using, but if its anything like the rocket launchers at maker faire, they have considerable range. great build, just shoot it off somewhere else next time.
    other than that small safety rant, nice job!
    DAE (ilpug)
    adrenalynn
    adrenalynn
    No. Paper "rockets" are not taking out the safety-glass of high-rise buildings. Sorry. Not gonna happen.
    The ones the kids typically build, even when over-taped, are 15-17 grams. They might crack window glass at point-blank ranges, _maybe_, but even right up against it they're just going to smush on safety glass.
    We've flown them with cameras at more than double the pressure the author of this I'bil notes. Although the muzzle velocity is high, the mass just isn't there.
    ilpug
    ilpug
    Yeah, I see that now... Still, not the best place, especially with fireworks attached.
    avgas
    avgas
    epic i can't wait to build one you should put a smoke bomb or bolt bomb in it !!!!!!
    LanceMakes
    LanceMakes
    11 years ago on Step 3
    Using an air nozzle for the trigger is a brilliant idea. Could you explain in further detail how to replace the solenoid with the compressed air nozzle? Also, where did you get the nozzle?
    Thanks!
    mvonsydow
    mvonsydow
    11 years ago on Step 8
    This is my version of the Compress Air Rocket Launcher. I've incorporated the launch stand into the air chamber and added a gauge to control pressure. Using 40 lbs of pressure, the rocket shown here has flown to 300 ft.
