Introduction: 4V Lead Acid Battery Charger
Note- You can use any Li-ion charger which is used to charge phone's 3.7v Battery as they both are charged with a 4.2V DC. but if you still want to make one of your own. just go through this instructable.
Here's a step-by-step guide to making a 4V lead acid battery charger using a 5V regulated supply:
1. Gather the materials needed for the project:
  - 5V voltage regulator (such as L7805)
  - Header pins or connectors for connecting the battery to the circuit
  - 1N4001 rectifier diode
  - ECB (Experimental Circuit Board), breadboard, or any other suitable prototyping board
2. Begin by connecting the components on the ECB or breadboard:
  - Insert the 5V voltage regulator (L7805) onto the board, ensuring it is oriented correctly.
  - Connect the input pin (Vin) of the voltage regulator to the positive terminal of your 5V regulated power supply.
  - Connect the ground pin (GND) of the voltage regulator to the negative terminal of the power supply.
  - Connect the output pin (Vout) of the voltage regulator to one end of the rectifier diode (1N4001).
  - Connect the other end of the rectifier diode to the positive terminal of the lead acid battery.
  - Finally, connect the negative terminal of the battery to the ground (GND) of the power supply.
3. Once all the connections are made, double-check them for accuracy and ensure there are no loose or shorted wires.
4. Plug in the 5V regulated power supply to a suitable power source.
5. The voltage regulator will regulate the input voltage to a steady 5V output, which will charge the lead acid battery connected to it. The rectifier diode prevents the battery from discharging back into the power supply.
Note: It's important to monitor the charging process and ensure the battery does not overcharge. Lead acid batteries typically require a specific charging profile to avoid damage or reduced lifespan. If you're unsure about the charging requirements for your specific battery, it's recommended to consult the manufacturer's guidelines or use a dedicated lead acid battery charger.
Remember to exercise caution when working with electricity and follow safety precautions to prevent any accidents.
Step 1: The Circuit
To ensure proper functioning of the battery charger, it is essential to have a DC power source with a voltage greater than 7 volts. You have a couple of options to obtain such a power source. One option is to connect a laptop charger with a DC jack, while another option is to utilize a set-top box adapter. Once you have secured the appropriate power source, you can proceed with connecting the battery to the output of the voltage regulator.
For a more detailed visual representation of the circuit, please refer to the provided pictures.
Step 2: FINISHED ............
