Introduction: Aquaponics System
Aquaponics System is a closed loop ecologically balanced system that combines the cultivation of plants without soil and the cultivation of fish (hydroponics and aquaculture). It is essentially a mini ecological system where the plants care for the fish and the fish care for the plants symbiotically.
Aquaponics is considered the most natural method of growing organic produce as the produce is entirely free of chemicals which surprisingly not all organic produce . It is also a very effective method of caring for your fish because the filtration system is natural, continuous and it oxygenates the water. Remember: With a little bit of determination, anyone can do this!
Step 1: Basic System Design
In an aquaponic system, water from an aquaculture system is fed to a hydroponic system where the by-products are broken down by nitrification bacteria into nitrates and nitrites, which are utilised by the plants as nutrients, and the water is then recirculated back to the aquaculture system.
In its most basic sense, is all an aquaponics system is? And although you might feel that this is too simple, remember that you can expand on this core design and implement it for your specific needs in an almost infinite variety of ways.
Note: above image is referenced only
Step 2: Step: Components & Materials
Start manufacturing your own Aquaponics System free by downloading and 3D printing parts here. You will also need to source a fish bowl, pump, and flexible tube all of which can easily be sourced from Amazon and eBay etc .
Parts info: – 250mm diameter fish bowl with a 150mm diameter opening.
– 300L/hour submersible pump.
– 7mm tube.
- clay pebbles (as for requirement )
- algae remover for aquariums
- Net Cup Printables required qty’s: case1 (qty 1), Top case (qty 1).
Note: you may need to adjust the outriggers to suit your fish bowl.
Step 3: Reference
Net pot - https://www.google.co.in/search?q=Net+Cup&biw=136...
- algae remover for aquariums https://www.google.co.in/search?q=Net+Cup&biw=136...
- clay pebbles http://www.amazon.com/PLANT-GMC10L-Clay-Pebbles-4...
Desigen reference https://www.google.co.in/search?q=aquaponics&biw=...
If you’re ready to get started then I highly recommend you choose a step-by-step guide or course to help you.
vote for me , If you like it (any help I will be there and sorry for my English )
3D Printing Contest 2016
