Introduction: Beebeecraft Tutorials on Making Yellow Pearl Earrings
About: Hi, guys!! I’m Daisy. I love putting beads together to make jewelry work; sharing jewelry designs. If you like jewelry and beads, you are in the right place. I’ll regularly update new jewelry tutorials about b…
Do you like handmade earrings? Do you want to make one by yourself? How about learn to make a necklace with Beebeecraft during leisure time? Earrings are very ordinary jewelry and almost every girl has a pair of earrings in their jewelry boxes, and even more. Actually, pearl beads are extremely suitable for making earrings. There are hundreds of pearl earrings designs on our website. Today's DIY earrings project is also about a pair of easy pearl beads earrings, as you can see from the picture.
Step 1: Supplies Needed for the Pearl Earrings:
4mm Glass Pearl Beads
Golden Brass Earring Hooks Ear Wire Hooks
6mm Glass Pearl Beads Strands
30mm Stainless Steel Eye Pin
7~8mm Yellow Lampwork Beads Strands
Steel DIY Jewelry Plier Sets
Step 2: Bead a Basic Pattern of the Earrings
1st, use the eye pin to string 4 glass pearl beads of 6mm, and cross the two ends of the pin;
2nd, slide a white pearl bead ,a yellow lampwork bead and a white pearl bead in the eye pin, and cross the two ends of the pin;
3rd, make two strings of pearl beads and 8 strings of pearl lampwork beads;
4th, connect the ends of four lampwork beads strings and one pearl beads strings, as you seen from the picture.
Step 3: Finish the Pearl Earrings
1st, use the eye pin to string one glass pearl bead of 6mm, and cross the two ends of the pin;
2nd, fix the bead string at the opposite corner of the made beads string of step 2;
3rd, connect the earring hooks to the beads string, as you seen from the picture.
Step 4: Now, This Pearl Earrings Have Been Finished:
Wow! These earrings with lampwork beads and pearl beads are so delicate! Don’t you want to have a try? No need any professional beading or wire wrapping skills, just follow this Beebeecraft tutorial, even you are a green hand, you can make a pair at home.
