Introduction: Floppy Disk Succulent Planter
I have a huge box of floppy disks that I ma gradually finding projects to use them up on
Step 1: Supplies
Each planter requires:
5 x floppy disks (I like to use something interesting for the front these set is MSDOS 6.21, something plain for the sides and the base and something coloured for the back)
4 x Cable ties (I like to match the colour to the colour of the disk used for the back)
Cloth tape
Aluminium Tape
Silicone sealant (Hot glue would probably work just fine)
Step 2: Construction
- Lay the discs out to form a cross, make sure you leave a small gap between them, when assembled the discs sit on top of the base disc.
- Put a couple of small pieces of tape to hold the discs together while you cable tie the tops.
- Using the holes already in the discs cable tie them together, The side discs sit inside the front and back.
- Wrap the aluminium tape around the base and tuck underneath, this is the first step in waterproofing
- Then seal all the internal seams with silicone.
Step 3: Planting
- Mix the alpine gravel with a little of the cactus compost and place a layer in the base of the pots. Mixing the compost with the gravel helps to enable the water to drain through.
- Top up the rest of the planter with cactus compost
- Plant your plants
- Top dress the planters with Alpine gravel
- For most succulents place in a bright sunny spot without direct sun, water regularly during the growing season and less frequently during the winter.
- Enjoy
Planter Challenge
