How to Clean Leather Shoes
Supplies:
  • Leather shoes
  • Leather shoe cleaner
  • Leather shoe conditioner
  • Old towel
  • 2-3 clean rags
Teacher Notes
Step 1: Prepare Your Area
  • Lay down an old towel or paper towels on your work surface so that you will not risk making a mess
  • You will also want to make sure that you are in a well ventilated area.
Step 2: Unlace Your Shoes
  • Unlace your leather shoes
Step 3: Remove Dirt
  • Remove any dirt or excess buildup from your shoe using a rag or brush
Step 4: Apply Solution to Rag
  • Apply an approximately dime-sized drop of leather cleaning solution to a clean rag
Step 5: Rub Cleaning Solution In
  • With your cloth, apply the cleaning solution to the shoe using gentle circular motions
  • You will see the leather begin to absorb most of the cleaner
  • If there is too little cleaning solution, add more and repeat this step
  • If there is too much cleaning solution, do not worry, we will deal with it next
Step 6: Remove Excess Solution
  • With a new, clean rag, wipe any excess leather cleaner off of the shoe
Step 7: Apply Conditioner to Rag
  • Grab a new rag and apply a dollop of leather conditioner to the rag
  • You will want a little bit more of conditioner compared to the cleaner (about a quarter-size drop)
Step 8: Rub in Conditioner
  • Thoroughly rub the conditioner into the shoe
  • You should rub it in until you can no longer see the liquid conditioner
  • If you run out of conditioner before thoroughly covering the entire shoe, it is ok to use more conditioner
Step 9: Let It Dry
  • Allow the shoe to dry for a minute or two, especially the first few times you condition the shoe
  • This lets the shoe absorb the conditioner a little bit more
Step 10: Re-Lace Your Shoes
  • Lace your shoes back up and you are done!
Be the First to Share
    • Book Character Costume Challenge
    • Made with Math Contest
    • Cardboard Speed Challenge
