Introduction: How to Make a Basket From a Garden Hose
Three Methods:Identifying a Purpose for the Basket :Creating the Hose Basket :Making the Handle:
Create a unique and handy outdoor basket for your gardening tools or other small outdoor equipment using a regular garden hose.
Step 1: Identify Where This Outdoor “basket” Will Be Helpful.
Is there an area in the backyard where the gardening tools get thrown in the corner or do you need a handy holder for swim items like goggles, flippers, and/or pool toys? Figure out how you will integrate the basket into your outdoor decor, as this will likely effect the color and style of the basket you create.
Step 2: Choose a Color According to Your Purpose
Choose a color according to your purpose. While you could just create the basket from an old garden hose you have laying around, it's probably best to spring for a new hose in a color that matches your outdoor décor. If you hit the lawn and garden store you will most likely have several colors to accommodate your needs––they may even have some fancy patterns!Consider matching the zip tie color to the hose color or purchase zip ties in a complementary, contrasting color.
Step 3: Bend the Blunt Hose Nozzle in Half
Then bend it underneath itself. This will be the basis for winding the basket, so secure the nozzle snugly.
Step 4: Wind the Hose Around the Initial Circle Twice
Then add twist ties around the perimeter of the initial base to hold everything in place; wind tightly.Don’t let go of the hose as you secure the wound-up hose reel in place; keep the rest of the hose in the other hand.Use approximately four twist ties per circular round. Space the ties evenly around the perimeter for the firmest hold.
Step 5: Continue to Wind the Hose Around Itself to Create the Basket Base
Add twist ties around the perimeter of each circle and tie on tightly.
Step 6: Wind the Hose Until You Are Satisfied With the Size of the Basket's Flat Base
The base size will depend on personal preference and need; obviously larger baskets require more hose but can also hold a lot more
Step 7: Wind the Hose Around the Top of the Outer Base Circle.
This will begin to build the side of the basket.
Step 8: Add Twist Ties in Fours for Every Loop You Create.
Ensure that the twist ties are aligned and staggered. Continue up the sides of the basket until you consider it to be high enough for your needs.
Step 9: Secure the Last Loop When You Are Ready to Create the Basket Handle.
Depending on how large or high you made the basket, allow for approximately one foot (30.5cm) of hose to remain to create the handle with
Step 10: Wind the Last Twist Tie Around the Base of the Hose.
Start where you want the handle to begin and twist the hose around so it is facing the exact other side of the basket.
Step 11: Make a Large Loop With the Hose.
The loop should resemble a basket handle. Secure the bottom portion of the hose along the other side of the basket top.
Step 12: Secure the Remaining Portion of the Hose With Twist Ties
Consider placing a twist tie toward the end of the hose to avoid having the hose's mouth snag on items.
Step 13: Finished
Carry it out to its new spot in the garden and place items, plants or whatever else inside it.
