Introduction: How to Make a Powerful Miter Saw? With 895 Motor
Hello everyone! today i will show you step by step how to make a powerful and compact miter saw which is powered by 895 motor. Its work from 12-24v. This saw looks like a toy but it is really powerful little beast. Its allow you to cut boards at any angle. I set two most usable angles 90 and 45 degrees.
If you liked the video please subscribe to my YouTube channel!
Step 1:
All parts for this diy project i found on Aliexpress. I will live links to this parts below:
- 895 Motor 24V 12000RPM
- 895 Mounting Bracket
- Table Saw Accessories
- SK8 Rail Shaft Support
- Rod Rail Shafts 100mmX8mm
- LANBOO short touch button
- 5.5 DC Jack Socket
- 24V4A Switching Power Supply
P.S. If You like you can buy already made saw
Step 2:
First of all, i cut few boards. Sizes 4*8cm, 5*30cm, 20*30 cm. Material oak. Then i glued small piece of wood to the bigger one. That will be stand for the saw.
Step 3:
When the glue dries up, i make some marks for rail shaft support. Drilled few holes, and fixed rail shaft support with screws. Then i inserted rod rail shafts and check how it works. The spring is elastic and will withstand the weight of the motor.
Step 4:
I took an aluminum profile and cut off 20 cm. All wires will be hidden in this profile. Later i will cover holes with wood.
Step 5:
Now i will install 895 Mounting Bracket. Everything should be an right angle. Then i fixed 895 motor to the Mounting Bracket.
Step 6:
Now I'm assembling the saw blade shaft. Again checking if the angle is 90 degrees.
Step 7:
Now we should protect ourselves and our fingers from dangerous saw blades. To do this I use a broken metal angle grinder bracket. Fixed it with screws.
Step 8:
Now i'm installing touch button. The saw will work only when you pressed the button. If something goes wrong it will be stopped immediately. I marked where should be center for the button and drilled a hole for it.
As i already said all wires will be hidden in the aluminum profile. For this i drilled some holes in it.
Step 9:
Now im soldering wires to the bottom, motor and DC Jack Socket.
Step 10:
Now I'm making a guide for the saw. To do this, I use an aluminum corner and a protractor. Glued on the glue
Step 11:
I drilled a hole in base. Screw will be fixing protractor. So we can cut any angle.
Step 12:
I covered wood with some oil, to make saw look more beautifull.
Step 13:
It's time to cut something! I used 115 mm disk blade, so the deep of the cuts is around 4 cm. Its perfect for cutting small boards, aluminium profile and so one. The cut is smooth and clear.
So guys!
That's all. We made a small and powerful miter saw blade. Hope you like it! Thanks for watching and have a nice day!
Step 14:
