Introduction: How to Make a Real Bubble Solution
Here i am showing you how ot make a real best bubble solution using
guargum.The ingredients here i am using is little bit different to get a perfect output. Its a output is 100% sure and the bubble solution is better than the one we buy from market
Step 1: GuarGum Bubble Solution
Its very easy to make.We can make this bubble solution in 2 minutes with normal ingredients. GuarGum is the special ingredient here we used.
Step 2: Ingredients
1. 250ml hot water
2. 750ml normal tap water.
3. 1/4 tbsp GuarGum
4. 2 tbsp of rubbing alcohol
5. 50ml dish wash soap
6.1/2 tbsp of baking powder
Step 3: How to Make
  1. Mix 1/4 tbsp of gaurgum with 2 tbsp of rubbing alcohol and make a good slurry.
  2. Take 250ml of hot water and add the guargum slurry in to it and mix well.
  3. Add 750ml of normal water in to the mix and combine and mix all together.
  4. Add 50ml of dish wash soap and mix well.
  5. Add 1/2 tbsp of baking powder and mix.
  6. Remove the foam on the top of the solution.
  7. Bubble solution is ready.Keep the solution overnight for best result
