Introduction: Ice Claws
20 days ago I was in the field. And there was snow and ice...and I slip down. So, I decided to buy ice cleats/crampons. Well, here was limit on real alps high quality stuffs ... i.e. high prices. So, went to nearby metalworking shop...
Step 1: Start
See.
T profile plate 2 mm thick. with holes for screws. Zinc protected against rust. A 25 mm steel screws, zinc protected, for metal. Self drive in.
Step 2: Tool
I took a saw, a rasp and a rasp and a wrench....shorten T profile, extend holes for future strip, and start to screw bolts. Some holes should to be adjusted, to match the screw.
Step 3: Looking How Should Be Fastened
As you can see, some heads of bolts suddenly find a place between ribs...
Step 4: Reinforcements
In spite the bolts hold tight in T plate, to avoid unscrewing, I decide to use small torch and put simple zinc wire to fasten heads.... after I cleaned - wash this with gasoline.
Step 5: Testing
Well, later I add strip and clips, and tray it out in the field on frozen waterfall...
I menage to stand still and secure, to move, to climb, to take a photos ... from the point which is without this..... impossible.
Step 6: This Is That
That is this.
Well, now I have help, for eventual situation. Not heavily to carry in backpack, cheap and strong.
Its work for me,
Yours on your responsibility.
Sincerely yours.
