Introduction: MDF Workbench
Build a workbench for a hobby room or workshop.
Step 1: MDF
Cut 2ft width pieces of MDF.
Step 2: Top Frame
Build a frame for the tabletop.
Step 3: Shelf Frame
Build a second frame to support a lower shelf.
Step 4: Legs
Attach legs to the top frame. The legs in the back extend higher for storage.
Step 5: Support Shelf
Attach support shelf frame.
Step 6: Cross Beam
Attach another beam to support the MDF top.
Step 7: Foot Pads
Staple faux leather to the feet to prevent scratching the floor with movement.
Step 8: Shelf
Attach the OSB lower shelf.
Step 9: Shelves
Build shelves into the frame.
Step 10: Peg Board
Attach peg board.
Step 11: More Shelf
Build more shelves using the same principles.
Step 12: Sizing MDF
Mix 50/50 solution of wood glue and water. Brush on the edges of the MDF to seal. You can apply multiple coats sanding with 220 grit between if desired.
Step 13: Shellac
Put a coat of shellac on the MDF top. It evaporates quickly helping to pre-seal the top, readying it for Polyurethane.
Step 14: Polyurethane
Coat with polyurethane. The first coat will be partially soaked up by the MDF. Sand and apply a second coat.
Step 15: Glossy Sealed Tops
Tops are sealed.
