Introduction: Origami Chinese Takeaway Box
In this instructable I will show you how to make a Chinese takeaway box
below are some pictures of the finished product.
since it is origami, all you need is a square of paper.
Hope you like the instructable.
Step 1: Starting
To start you need to get you'r piece of paper and fold it in half
as shown ,unfold it and fold it in half again the other way.
Then you fold it to create diagonal creases by taking a corner and
folding it down to the other corner.Do this twice a s in the previous step.
Step 2: Square
Fold you'r paper into a triangle again.Lift up the corner that is on the top right
,open it up a bit then spuish it down to make a square.
Turn the paper over and repeat.
Step 3: Nearly Done
Take the corners of the square and fold them in to the
center line.Turn it over and repeat so that
both sides are the same.
Step 4: Final Adjustments
Take the open side of you'r shape and open it up.
You should then put it on a flat surface so it makes
it easier to flatten out the bottom.
Step 5: Done
Now your done !
Though if you are intending to eat out of your new box
I recommend you use thicker stronger paper than I did.
Thanks for viewing my instructable.
