RC FPV-Trike With Rear Steering Wheel
23,450
139
20
Introduction: RC FPV-Trike With Rear Steering Wheel
About: Like to make stuff
As I had some spare parts from my first FPV Rover, I've decided to build a RC car. But it shouldn't be just a standard RC car. Therefore I've designed a trike with a rear steering wheel.
Step 1: Parts to Print
Find all parts you need on Thingiverse
https://www.thingiverse.com/thing:3669829
I've printed all parts (beside the tires) in PETG. But any material is fine here. Tires are printed in TPU.
1x Body
1x Top part 1
1x Top part 2
1x Front fender left
1x Front fender right
1x Rear fender
1x Servo arm
2x Servo extension
1x Rear wheel attachment (Support needed)
1x Rear wheel
1x Rear tire (use TPU)
2x Front wheel
2x Front tire (use TPU)
Step 2: Parts You Need (BOM)
Step 3: Preparing Motors
The ESCs have a switch which you can keep if you want. If not, unsolder the two cables and bypass the two pins. So the ESC is always "on".
Solder the JST plug to the motor. You can solder the ESC directly to the motor, but it's easier to replace with the plug if something broken.
Add 4 M3 nuts to the body and attach the motors with 4x M3 x 25mm button head screws
Step 4: Add Magnets to Body and Top
You need 16 magnets 6mm x 3mm for the body and the top.
Use CA glue to keep them in place.
Step 5: Rear Wheel Attachment
The rear wheel has build-in-support on one side where a bearing belongs to. Cut this with an exactor knife and open the hole
Step 6: Prepare Servo and Servo Arm
Cut the edges from the original servo arm to fit into the enlarged servo arm.
Step 7: Attach Rear Wheel to Body
Step 8: Front Wheels and Electronics
Attach the front wheels to the motors. They should press-fit to the motor shaft.
To secure the ESC to the body use hot glue, velcro or double sided tape.
Step 9: FPV-Camera and GoPro Mount (optional)
If you use a FPV-Camera, I do recommend to use one of the protectors. I use the one where I can attach the GoPro to it.
To secure the FPV-Camera, you'll need one rubber band.
In my case, the camera is powered by an own battery. It is a small 1s from an Eachine E010. For this, the top has a compartment where you can place the battery.
If you want to power the FPV-Camera from the trikes battery, you'll need a step-down-converter, as the trike uses 3s.
Be the First to Share
    • Audio Challenge 2020
    • Maps Challenge
      Maps Challenge
    • Backyard Contest
      Backyard Contest
    20 Discussions
    Fredkaz245
    Fredkaz245
    Question 4 days ago
    Link for the 3D printed parts is not working, keep getting a 404 page not found when you try and download the files. is it possible to share another way please.
    blackiyto
    blackiyto
    1 year ago
    Oh wow! I thought you were controlling each of the motors to turn the front wheels at different speeds in order to guide the car.
    Tutoapp 9AppsShowbox"}"
    askjerry
    askjerry
    1 year ago
    Since I didn't see anything attached tot he GoPro, I presume you are simply using the GoPro App to view the video on-the-fly. Nice build... I like that all the major parts can be printed... and I like the use of the magnets to close the cover. Nicely done.
    markus.purtz
    markus.purtz
    Reply 1 year ago
    Thanks a lot. The GoPro is used only for recording. For FPV I use just the little AIO camera.
    If you want to use the GoPro as FPV cam, you need an additional FPV transmitter.
    askjerry
    askjerry
    Reply 1 year ago
    I must have missed the section where you showed how to wire up the camera and what software to use... I'll have to read it over again after work. Thanks.
    markus.purtz
    markus.purtz
    Reply 1 year ago
    There is no section yet, as I did it two days before my holidays :-D
    As I have the trike with me, I'll try to do this in the next days.
    The AIO camera needs 3.7v. So you would need a step-down converter from the 12v.
    As I had some spare parts from my tiny-whoop clone (batteries) I use these to power the cam. So you don't have to solder a step-down to the battery and you don't have to unplug the camera, if you take the top down.
    askjerry
    askjerry
    Reply 1 year ago
    Nice... I'll have to look into that camera. Alternately... if you have your cell phone with the GoPro App... you could use that... I've tested it up to 400 feet.
    markus.purtz
    markus.purtz
    Reply 1 year ago
    Hi askjerry,
    I've included a new step to this instructable for the FPV cam. Hope this helps you. If you have any further questions, let me know
    JohnC430
    JohnC430
    1 year ago
    Unless I am misunderstanding this.: The front wheels turn at the same speed, and the back wheel does the steering, which means that the front wheels are dragging.
    if not then what makes the front wheels turn at different speeds?
    VinczeZ
    VinczeZ
    Reply 1 year ago
    I'm tinking the same. Also the whole steering would be much simpler that way.
    markus.purtz
    markus.purtz
    Reply 1 year ago
    With the right transmitter, this shouldn't be a problem. But then you have to dismount the servo for steering, so that the rear wheel is "loose". But with this it would be hard driving backwards.
    markus.purtz
    markus.purtz
    Reply 1 year ago
    Hi John,
    the two motors run at the same speed and steering happens by the rear wheel.
    I don't know if it is possible to run the motors on different speed with this transmitter.
    For my FPV Rover (https://www.instructables.com/id/FPV-Rover-V20/) I use "differential thrust". But for this I use the Taranis as transmitter with a lot more functions.
    TheCurmudgeon
    TheCurmudgeon
    1 year ago
    What would make this a outstanding build would be to include a pan/tilt mechanism for the FPV camera. That would take an already good project and add a bunch more capability to it.
    michaelb2
    michaelb2
    1 year ago
    Clean design.........do you see an advantage of a steerable rear wheel over a swivel wheel and diferential drive wheels?
    markus.purtz
    markus.purtz
    Reply 1 year ago
    Well, I wouldn't call it advantage, but the steering is "aggressive" with a rear steering wheel. It's like driving backwards with your car and steering.
    stephenpearson171
    stephenpearson171
    1 year ago
    Great instructable. What receiver did you use with the fpv camera?
    seamster
    seamster
    1 year ago
    This is slick! Love the design, very well done! : )
    markus.purtz
    markus.purtz
    Reply 1 year ago
    Thanks a lot. Hope to see a build from you here and on thingiverse
