Introduction: RFID Door Lock With Arduino
About: i am a student in Pakistan and have a good knowledge about Arduino Instagram Account: probotlab GitHub Account: probotlab
Basically this project is all about how to make your house,office place and even your personal lockers.This projects makes you understand arduino with RFID and how are the connected together .
So lets get started
Step 1: Things Required
  1. Arduino uno R3
  2. RFID reader RC522
  3. RFID cards
  4. Plunger
  5. relay
  6. Jumper wires
  7. Battery 9 Volts
Step 2: Connecting RFID
ARDUINO to RFID reader
pin 11 to MISO
pin 12 to MOSI
pin 13 to SCK
pin 10 to NSS
pin 9 to RST
These were the connection from Arduino to RFID reader
Step 3: Relay
As we are using a plunger it requires 9 volts to work and as we all know an Arduino uno only has max 5 volts . In this case we will then use a relay so we can make it work too.We are using the plunger as a lock .So here is the connections for it :
Arduino to Relay
pin 4 to pin S
5 Volts to pin +
Ground to pin -
Now comes the power in and power out switch
Power in switch should be connected with the battery and power out one with the plunger and connect one of the plunger wire direct with the battery.
Step 4: Code
https://github.com/omersiar/RFID522-Door-Unlock/
This is the link for the code
uplode the code to arduino and enjoy having an rfid code thanks
