Introduction: SWAN ILLUMINATED BY LED RGB ON COPPER PLATE CYGNE ILLUMINE EN RGB
The purpose of this tutorial is to create a decorative cardboard box ,
it is used to color paper 250 gr / m² to make the box, the epoxy plate on which was engraved the image is pasted .
Then the epoxy plate is illuminated with RGB LED that changes color automatically
download the demo at the end of this tutorial
Le but de ce tutoriel est de créer une boite décorative en carton, pour cela on utilise du papier de couleur 250 Gramme /M² pour fabriquer la boite, on colle la plaque époxy sur laquelle on a gravé une image.
Ensuite on éclaire la plaque époxy avec une LED RGB qui change de couleur automatiquement
le tutoriel et les demos en Français se trouve dans la fichierZIP à la fin
Step 1: MATERIAL:
Epoxy copper plate presensitized
Developer for epoxy presensitized
ferric chloride
5mm RGB Slow Flash Rainbow MultiColor Red Green Blue LED
2-component epoxy adhesive
cyanoacrylate glue
slide switch
zéner diode 3, 3 volts
resistance 560 Ohms
4 batterys 1.2 V or 4 x 1.5 V AA
battery holder for 4 AA batterys
color paper 250Gr / M ²
transparent printing ink jet or laser
scissors
cutter
ruler
scotch
flexible wire 0.6 mm
soldering iron and solder
Step 2: SOFTWARE:
Google Sketchup 8:
http://www.sketchup.com/intl/fr/download/gsu.html
Inkscape :
http://inkscape.org/?lang=en
Flattery plugin for sketchup 8:
http://sketchuppluginreviews.com/2010/04/12/flattery-google-sketchup-plugin-review/
Gimp 2.8:
http://www.gimp.org/
Step 3: Achievement
Step 1:
converting a color image to black and white mask with Gimp
http://youtu.be/vpbASoEWg0Y
on the video we see :
how céer a black and white mask with GIMP to print on a transparent
Tip ! If you use an inkjet printer to print it and layer 2 transparent
for a copper engraving well mixed.
I have not filmed the steps of exposure of the plate to ultraviolet and engraving perchlorure
because there are many videos on youtube about
Step 2:
creating a box and registration SVG with SketchUp 8
http://youtu.be/NEv4nUmKoYY
how to install the plugin flattery
how to create 3D box
how to build the box and create tab sticking with flattery
how to export all the SVG
Step 3:
resizing with Inkscape
http://youtu.be/-mCNwQvTtac
how to resize the drawing to print on a sheet of A4
Step 4:
http://youtu.be/1zGYLKVeHdE
Step on video
Step 5 :
http://youtu.be/Sess6ImgtuY
finished box demo
Downloads Links:
transparent, Inkscape , SketcUp8 files used in this instructable:
http://sdrv.ms/18HS6jF
Construction Links PDF files:
English-1/2
http://sdrv.ms/1bfY6z9
Français 1/2
http://sdrv.ms/18cIMjs
Français English 2/2
http://sdrv.ms/18cJqOb
Make It Glow Contest
