Introduction: Simple Homemade Lightbulb
Why did I make this?
Every year the cost of electricity rises. Many a times, there are long power cuts in the rural areas too. The poor cannot afford tubelights and their homes are filled with darkness. This lightbulb was invented by a poor man in the Philippines, and I was very inspired by him.
This is mainly to be used in rural and/or poor homes.
It uses no electricity, just simple household items and takes only a few minutes to make.
Moreover, it produces the light of a 60-watt bulb!
Keep in mind, a hole has to be made in the ceiling so choose where you want to put this before beginning.
So what are you waiting for, let's get started!
Step 1: Materials
All you need is :
1) Clean soda plastic bottle (Sticker removed)
2) Water (Preferably distilled)
3) Bleach *I forgot to take a pic*
Optional :
A funnel to pour the liquids
For fixing :
1) A scrap asbestos sheet *not pictured*(Or any other metal sheet)
2) Rubber sealant *not pictured
That's it!
Step 2: Spreading the Light
The water is used to spread the light over a large area.
Fill the bottle almost till the top. (Not too much! We need some space for the bleach.)
Step 3: Adding the Bleach
Add two or three teaspoons of bleach to the water and screw the cap on.
This helps prevent growth of algae in the bottle. (Ewwww.....)
Step 4: Fixing It
For this part you need to find a suitable place in the ceiling.
Make a hole in the asbestos sheet the diameter of the bottle. Push it halfway through, and use rubber sealant fix it in place. Then, fix the asbestos sheet in the ceiling
Step 5: The Finished Product
Sorry for the lack of pictures but-
The end result is an amazing cheap bulb which :
a) Gives light equivalent to a 60-watt bulb.
b) Lasts for 5 years or more.
c) Requires no maintenance.
The downside is that you can only use it during daytime :( (You can still use it in an attic or any dark space)
Thanks for seeing this instructable and favourite. Also, any suggestions will be welcome :)
Green Electronics Challenge
Green Design Contest
