Introduction: Simple Pallet Book Shelf
Hello today, we will continue with pallet.
I need a book shelf, so I will use some pallets to build it.
Lets go and when it's free is better.
Step 1: Matérials
You will need :
- pallets
- wood screws
- glue
- sandpaper
wooden pegs
hammer
- circular saw
Step 2: Clean and Cut Pieces
After having disassemble the pallet, we clean the wood with a good sanding with sandpaper 80.
Then blocked again the holes with sawdust and glue wood. Then another sanding with sandpaper 200.
Now cut the boards to the desired length.
I have six boards 10 * 100 cm and 4 boards 10 * 50 cm
Step 3: Assemble
Six boards 10 * 100 cm, I assembled them together with wooden pegs and wood glue to create 3 boards 20 * 100 cm.
Same with the four planks 10 * 50 cm which will give me two boards 20 * 50 cm.
After dry, I sanding again with 200 grid sandpaper.
And now I assemble the pieces with wood screws.
Then a coat of clear varnish to protect it all and it's over.
Total 5€ and 6 hours, it remains only to him found a place on a wall.
Pallet Contest
Reuse Contest
