Star Shaped LED Jewelry
155
About: I am IT professional, living in Bangalore, India. As new gadgets come out everyday, we indulge in spending significant time and money on these gadgets. And our kids are learning from us, they know how to use...
Hi All,
Few months back I came across an instructable https://www.instructables.com/id/LED-Jewelry/ by jiripraus
I wanted to try the making one, for my wife and she wanted a Star shaped LED jewelry. I did a google and could not find any template for it. So I decided to make one myself
In this instructable I will share how to design and make your own led jewelry
Teacher Notes
Step 1: What Do We Need ?
  • Brass wire 21 Gauge ( approx 0.9mm)
  • LED Strips ( white ) or smd LEDs
  • CR-2032 battery
  • Soldering iron
  • Paper tape
  • one A4 Sheet
  • Pencil, compass, and a measuring scale
  • Cutter
  • Pliers Small
  • Multi-meter
Step 2: SMD LED
  • I extracted my LEDs from an old LED strip
  • These were white SMD LED
  • Approx 3 mm X 2 mm X 1.5 mm ( L x W X H )
  • Had a T sign on it which indicated the cathode for the LED
  • Carefully de-solder these leds from the strip
  • I needed 6, but i extracted 9 of these, just to be sure that I had enough to work with
  • Test the LEDs to make sure they are still working, replacing LEDs later is bit difficult
Step 3: Design Principles
  • The jewelry has to be as compact as possible, we need to use the smallest battery avaliable
  • We are not building a torch, do not use extremely bright LEDs
  • Joints should not have sharp edges
  • It should look simple and elegant
  • Measure the battery, LEDs and wire
  • My Battery was 20 mm in diameter
  • The star is made with a circle with 40 mm diameter, one could chose to make it more bigger depends on one's preferences
Step 4: Star Outline
  • Trace the outline with brass wire
  • To get better star shape we have to cut the brass wire as shown and then soldered the joints
  • Stick the wire in place using paper tape
  • Remember to file the joints, so that there are no sharp edges
Step 5: Add LEDs
  • The Star outline will be connected to positive end of the battery
  • So solder anodes of all 6 LEDS to the star as shown
  • Add joints to connect all cathodes of 6 LEDs as shown
Step 6: Add Hook
  • Since this is a going to be a pendant, We need a hook
  • Twist and cut a small hook of brass wire
  • Solder it flat to the star
Step 7: Battery Support
  • On the back , we will add two battery supports to hold the CR 2032 battery in place
  • one of the support is as the diameter and another at the bottom
Step 8: Finishing
  • Inspect the LED jewelry for week joints and add soldering where needed
  • Insert the battery and test all LEDs
  • Hook it in a chain and we are done
I hope this instructable will inspire you to design your own shape and make one
thanks for reading
Reuse Contest
This is an entry in the
Reuse Contest
Be the First to Share
    • Instrument Contest
      Instrument Contest
    • Make it Glow Contest
    • STEM Contest
      STEM Contest
