Introduction: Voice and Button Automation for Disabled
INTRO:
The biggest problem in disabled persons is their inability to access things easily as others. But, our modern technologies and our super brain has made them possible to achieve great heights. This project is a Arduino-based project used to give home automation through voice and buttons which is available in my own android application made with MIT app inventor ."Talk less work more", So let's begin:)
The supplies required for this project are:
Arduino UNO / Arduino NANO
Bluetooth module HC-05 / HC-06
Relay module ( not used in video )
Bluetooth app (given)
Arduino IDE
Few minutes
jumper wires
wire extension box ( not used in video )
Any appliance (fan , light ,phone)
Step 1: Give the Connection As Given
BLUETOOTH MODULE - ARDUINO
VCC >> 5V
GND >>GND
TX >> RX
RX >> TX
LED - ARDUINO
LED 1 - ARDUINO
SMALL LEG (CATHODE) >> GND
LONG LEG (ANODE) >> 3
LED 2 - ARDUINO
LED 3 - ARDUINO
LED 4 - ARDUINO
Step 2: APP FOR ARDUINO
BLUETOOTH APP FOR ARDUINO
BLUETOOTH APP FOR ARDUINO IS VERY IMPORTANT.
I HAVE USED MIT APP INVENTOR TO CREATE ONE
THE APP IS GIVEN:
https://drive.google.com/open?id=1B_BuBoj6zpGicyffwOf7ZPOfiJ98bq18
Step 3: CODE
THE MOST IMPORTANT THING - CODE IS TO BY GIVEN IN ARDUINO IDE
CODE:
IF THE CODE GIVEN HERE DOESNT WORK, USE THIS GOOGLE DRIVE CODE:
https://drive.google.com/open?id=1WXx7sfJNFIaewOpjbv31hVg6VkUIcrBC
///////////////////////////// // A project by adithya** // //for instructables contest// // home automation project // //speech,text,button access// ///////////////////////////// ////////////////////////////////////////////////////////// ///*pin settings only for arduino uno and arduino nano /// ///**modification in code is not to be done /// ////////////////////////////////////////////////////////// #include <SoftwareSerial.h> String voice ; //declaring voice int tv = 3; //defining pin in arduino*for tv int light = 4; //defining pin in arduino for light int phone = 5; //"charging phone int fan = 6; //"fan int Received=0; int tv_state = 0; int light_state = 0 ; int phone_state = 0; int fan_state = 0; void all() { digitalWrite(fan,HIGH); digitalWrite(tv,HIGH); digitalWrite(light,HIGH); digitalWrite(phone,HIGH); } void setup() {//defining the devices at the outputs// Serial.begin(9600); pinMode(tv,OUTPUT); pinMode(light,OUTPUT); pinMode(phone,OUTPUT); pinMode(fan,OUTPUT); } void loop() { // put your main code here, to run repeatedly: //declaring voice control while(Serial.available()) { delay(10); char c=Serial.read(); if(c== '#' ) {break; } voice += c; } if (voice.length() >0) { Serial.println(voice); //voice commands if (voice == "TV" ) { digitalWrite(tv,HIGH); } else if (voice == "light" ) { digitalWrite(light,HIGH); } else if (voice == "charge" ) { digitalWrite(phone,HIGH); } else if (voice == "fan" ) { digitalWrite(fan,HIGH); } else if (voice == "all" ) { all(); } //voice off commands if (voice == "TV off" ) { digitalWrite(tv,LOW); } else if (voice == "light off" ) { digitalWrite(light,LOW); } else if (voice == "charge off" ) { digitalWrite(phone,LOW); } else if (voice == "fan off" ) { digitalWrite(fan,LOW); } else if (voice == "all off" ) { digitalWrite(fan,LOW); digitalWrite(light,LOW); digitalWrite(tv,LOW); digitalWrite(phone,LOW); } voice=""; } /////////////////////////////////////////////////////////////// /// END OF VOICE COMMAND PROGRAM /// /////////////////////////////////////////////////////////////// //XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX// //XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX BUTTON COMMANDS XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX// //XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX// if (Serial.available()>0){ Received = Serial.read(); } //xxxxxxx TV xxxxxxx// if(tv_state == 0 && Received == '1') { digitalWrite(tv,HIGH); tv_state=1; Received=0; } if(tv_state == 1 && Received == '1') { digitalWrite(tv,LOW); tv_state=0; Received=0; } //xxxxxxx LIGHT xxxxxx// if(light_state == 0 && Received == '2') { digitalWrite(light,HIGH); light_state=1; Received=0; } if(light_state == 1 && Received == '2') { digitalWrite(light,LOW); light_state=0; Received=0; } //xxxxxxx PHONE xxxxxx// if(light_state == 0 && Received == '3') { digitalWrite(phone,HIGH); phone_state=1; Received=0; } if(phone_state == 1 && Received == '3') { digitalWrite(phone,LOW); phone_state=0; Received=0; } //xxxxxx FAN xxxxxx// if(fan_state == 0 && Received == '4') { digitalWrite(fan,HIGH); fan_state=1; Received=0; } if(fan_state == 1 && Received == '4') { digitalWrite(fan,LOW); fan_state=0; Received=0; } } //////////////////////////////////////////////////////////////end of button /////////////////////////////////////////////////////////////////////</p><p>///////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////// //////////// END OF PROGRAM //////// ////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////</p><strong></strong><u></u><sub></sub><sup></sup><del></del><br>
Step 4: TESTING
TIME FOR TEST:
TESTING IS GIVEN IN THE LAST PART OF THE VIDEO
USE THE LED TO TEST AS IT IS SAFE
ENJOY THE PROJECT THANK YOU!
THANKS FOR INSTRUCTABLES
Assistive Tech Contest
