Introduction: Knex 1-shot Pistol With Real Trigger
A very simple but effective pistol. The power is dependent on the elastic bands used.
Step 1: The Barrel
Easy to make and you can do it from the picture alone.
Step 2: Handle
Easy and make from pictures yet again.
Step 3: The Frame of the Gun
Same here as well, just copy the pictures. This one is a bit more tricky. The last picture is viewing it from the other side.
Step 4: Little Bits and Trigger
The easiest bit.
Step 5: Assembly
Just follow the pictures.
Step 6: Elastic Bands
Just put the elastic bands where it shows. Easy. On the first picture just twist the elastic band around the rod to absorb shock.
Step 7: Loading
Just pull back the firing rod, push up the trigger then stuff in the ammo.
2 Comments
13 years ago on Introduction
Its onlt a block trigger, its not very good... Sorry, but i can only give you 2*
Reply 12 years ago on Introduction
In that case, every knex gun is a block trigger. This is, in fact, one of the most efficient and reliable true trigger designs I've ever seen.
