Introduction: All Natural Diy Hair Styling Pomade
Recently I've been really into hairstyling so I've been trying out a whole lot of different hair products and don't get me wrong here a lot of these products are great but some of them are indeed pricey. For instance, when I got my hair cut at the end of June I purchased the hair wax that the stylist used in my hair and for 8.5oz (250ml) it was 25$. But some name brands will sell around 2-3oz for the same price. Hair products can not only be expensive but a lot of them also contain a lot of harsh chemicals that can cause hair damage and those 5 minutes of hairstyling every morning can turn into months of restoration. So in this instructable I'll be telling you how to make your own hair styling product that doesn't contain any harsh chemicals, can be made for a fraction of the price of a regular product, and works just as great! So here I present you with All Natural Diy Hair Styling Pomade!
Ps, I'm really sorry for the bad quality photos. I shot every photo off of my iphone and I had to do it really quickly so I could keep up with making my own pomade.
Step 1: Ingredients
This project isn't rocket science so you're measurements don't have to be 100% accurate but ideally you'll want to have 1 part beeswax and 1 part coconut oil or Shea butter (Shea butter will make your pomade less greasy.) but if you add a bit more beeswax than coconut oil or Shea butter your pomade will have a stronger hold and if you add more coconut oil or Shea butter your pomade will give you more shine. So you'll have to experiment and see what works best for you.
So what you'll need is:
1)beeswax (I bought 3 1oz beeswax cakes for around 6$ and free shipping off of Amazon.ca
2)coconut oil or Shea butter
3)some sort of oil (I'm using avocado oil but any other oil will work. (Olive oil, almond oil, jojoba oil, grape seed oil, etc...)
4) any essential oil for scent (completely optional, I won't be using any today.)
5) some sort of tin or jar to keep your product in (I'm just using a jar that used to have skin cream in it, but something like an altoids container would work just as great.)
6) a bowl (mine's stainless steel), preferably one you don't want to ruin
7) a pot to boil water in
8) disposable utensils so you don't ruin any good ones
9) a tablespoon to mesure the oil in
10) a towel
Step 2: Melt Everything Together
First things first, pour around 750ml (this might vary depending on the size of your pot) of water into your pot and start to boil it. Then, in your bowl put in around 1 part beeswax and 1 part coconut oil or Shea butter, I'll be using roughly 1oz of each because I'm using a 2oz jar. Then once you've done that put the bowl into the pot of water to make sort of a makeshift double boiler. You could also use a regular double boiler. While it's melting mix it occasionally with a disposable spoon.
Step 3: Add Your Oil
Once everything's about half way melted add 2 tablespoons of your oil and keep mixing.
Step 4: Finish Up Your Pomade
After everything's melted you can add a few drops of your essential oil. Then you'll want to wrap the towel around your hand so you don't burn yourself while pouring the mixture out of your bowl and into your container. After you've poured the mixture into your container let it sit until it hardens. While it's hardening I would suggest you stir the mixture so it's easier to get out of the container later.
Step 5: The End Result
Now you can style away with your new homemade hair styling pomade! Not only did you just make your own hair styling product but if you add a little Vitamin E you've also made yourself some skin cream and lip balm! To use this product, simply scoop out roughly a dime size amount of product (remember, a little goes a long way) and rub it between your hands to spread it out evenly, then style as desired. If for some reason you decided not to stir the mixture while it was hardening, simply use a blow dryer to heat up your pomade a little so you can get a scoop out. This product holds your hair up very well while staying pliable throughout the day. Well, thanks for reading and let me know what you think in the comment section. I'd also love for you to post a picture in the comments of how yours turned out and how you style your hair with it. T'ill next time ;)
First Prize in the
Hair and Makeup Contest
Runner Up in the
Wax Challenge
17 Comments
Tip 1 year ago
I've made both this one and the other pomade projects. When I made this one, I stirred the contents and ended up with a lot of crumbs that I had to pick out before using on my own hair. The next time, I just poured it and let solidify in the container and got a very firm (but totally smooth) texture that had no crumbs.
7 years ago
Hi again. Now that I got hold of beeswax. I will be making hair pomade for my husband. Il post the picture once it is set
Reply 7 years ago
Great I look foreword to seeing how yours turned out!:)
Reply 7 years ago
I used 2:2:1 beeswax coconut oil and almond oil. It turned out good but not suitable for winters as coconut oil is cold
Reply 7 years ago
You could try using Shea butter as an alternative I personally haven't tried it because coconut oil is cheaper and more available but experimenting might just do it.
7 years ago
what's the consistency like?
Reply 7 years ago
depends on how much of what you put in it and wether you stir it or not
8 years ago
Congrats on winning judge prize in hair makeup contest and on being finalist in wax contest
Reply 8 years ago
Thanks!:) I really appreciate the support.
8 years ago
Oh sry I meant vitamin E capsules
8 years ago on Introduction
You have my vote! This head of unruly curls is grateful.
Do you suppose I could use less beeswax and add vita E for a softer product? Approx. how much E would you suggest be added. Thanks!
Thank you so much! Yes less beeswax will make the product softer and give less hold and for vitamin E I'd cut open maybe more or less 2 vitamin E pills. Thanks again I'm always happy to answer questions:)
8 years ago
I voted for you too. Good luck in the competition
Reply 8 years ago
Thanks. I really appreciate the support:)
8 years ago
Try www.bulkapothecary.com for beeswax and other ingredients, they have lots of great stuff and the best deal for quality bulk coconut oil I've found. Also www.mountainroseherbs.com has the best quality eo's for your buck, in my opinion.
Reply 8 years ago
Thanks. I'll be sure to check it out:)
8 years ago
I actually like this idea. I might try this some day once I get hold of beeswax
