Introduction: Aquatic Turtle Tank With Underwater Tunnel
Minette is our pet, it's a 13 year old Pelomedusa subrufa.
Nearly 10 years ago, I made her a 100-liter aquarium, since she grew up well and she needs more space !
On the occasion of a visit to a landscaper, I found this abandoned 450-liter aquarium which was kindly given to me by the owner.
I transformed rustic into modern furniture to adapt to our decor and I turned the aquarium into a turtle aquaterrarium.
Main supplies:
- 450 L tank with furniture
- Solar Raptor HID Lamp, ballast and a Clamp Lamp
- Tetra HT 150 Heating
- JBL Cristal Profi E900 filter
- Epoxy resin type R123 Soloplast 1 KG
- Strip led
- Poster
- Polystyrene, paint, accessories...
- Minette !
Step 1: Furniture: the Transformation
I dismantled all the elements that were too old: moldings, feet ...
I replaced the feet with wheels to make it easier to move.
I cut the 2 door jambs to move them to the center. The purpose is to replace the 3 doors, by 2 square doors and smooth.
Step 2: Furniture: Modernization
Sorry for those passionate about oak furniture!
I sanded the varnish so the glue adhered better, and then I cut panels in 10mm thick MDF. I put these boards with wood glue and I added nails with a pneumatic nailer.
I closed the groove of the molding and the nail holes with wood paste and I sanded the whole.
Step 3: Furniture : Painting and Finishes
To have a nice finish, I used a paint gun. I applied 3 layers of white and I painted the top border in black.
For doors, I used commercial models (Ikea) with its brake hinges.
Step 4: Aquaterrarium : Cleaning
In the past, the aquarium was used for reptiles.
I cleaned it all up and filled it with water to make sure it was waterproof.
The aquarium has a capacity of 450 L (150x60x50 cms) and the window are 13 mm thick. For the weight, I do not know but it is very heavy!l lol
Step 5: Aquaterrarium : the Underwater Tunnel
I wanted to make a decorative tour tunnel as we see in amusement parks.
I retrieved a neon outdoor lighting tube and cut it to keep only half. For the ground, I cut a transparent plexiglass strip.
I pasted small modelism characters and some phosphorescent stones for more realism.
I added 2 RGB LED strips and closed the tunnel with special silicone aquarium. It has the advantage of not being toxic to aquatic organisms.
I had several leaks, so I started laying the silicone several times...
Step 6: Aquaterrarium : Cave Lanterns
For the next step, I needed 2 small lanterns. So I modeled them in 3D with Fusion 360 and I printed it with my 3D printer won on Instructables! FlashForge Finder.
I had a lot of stringing because of a head temperature too high for PLA carbon.
I integrated 10mm RGB LEDs in the lamp before gluing the lid. I then glued small windows recovered in a package.
The 3D file is available for download.
Step 7: Aquaterrarium : Cave
Under the decoration, I created a cave, it only serves as decoration.
I used polystyrene that I stuck and reinforced with wooden picks.
I painted the decor in black and I added artificial plants, a dinosaur skull and 2 lanterns to the ceiling.
Step 8: Aquaterrarium : the Decor
The main decoration has a part out of the water and it is sloping so that the turtle can easily get out of the water.
It is cut in a large block of polystyrene with a saw handsaw. It is then heated with a heat gun to harden the surface before painting.
I also integrated a t-rex skull with expansive foam.
Step 9: Aquaterrarium : the Assembly
I started by sticking the cave and I locked it in a waterproof box. Even if the water should not come so far, it will protect the cave in case of leakage. We'll see later that it was not enough :(
I stuck the tunnel and used tile trim strips to hide the joints.
Then I installed the styrofoam block and filled all the tower with expansive foam.
Step 10: Aquaterrarium : Paint and Resin
I applied 2 coats of anthracite paint then I resinated to make the decorations waterproof and resistant.
I used R123 epoxy resin and R614 hardener (Soloplast). It is important to follow the instructions carefully so that the resin is not toxic to animals! I put 3 coats of resin with a brush, insisting on the edges and I did several cleanings. The treatment was spread over 1 month !
I finished with a silicone seal on the edges.
Step 11: Aquaterrarium : Last Details
In the background, I pasted a poster with spray glue and to hide the polystyrene, I stuck black vinyl on the windows.
For the filter, I kept the JBL CristalProfi of the previous aquarium
Step 12: Aquaterrarium : the Heat Lamp
I chose a Solar Raptor lamp, It is a 3 in 1 bulb that offer both heat, UVa + UVb and intense light, the ideal solution for turtles!
I installed it on a board on I covered black vinyl.
Step 13: It's Over !
It's over ! Minette can now enjoy a great space for swimming and a heated beach!
Step 14: Fail
I underestimated the power of water! Despite all the precautions, the water ended up under the decoration, began to flood the cave, and there is even a little water that entered the tunnel!
So I turned off the LEDs of the tunnel as a precaution, and for the cave, I leave the lanterns on but I monitor the water level...
![Pets Challenge](https://content.instructables.com/FE3/26CT/JWESTZTA/FE326CTJWESTZTA.jpg?auto=webp&frame=1&width=320)
Pets Challenge
