Introduction: Blue Dangling Earrings DIY
Here is something amusing and feminine for both girls and ladies to wear-a pair of dazzling DIY dangle earrings. What’s more, for giving the dangle earrings more radiant appearance I choose the cat eye beads as main part of them. The fascinating light and gorgeous gloss will help your design more impressive.
Step 1: You'll Need:
8mm cat eye bead
4mm Bicone glass beads
Headpin
Eyepin
Brass chain
Wire-cutter Pliers
Side Cutting Pliers
Round Nose Pliers
Step 2:
1. Slide one 8mm cat eye bead onto the eyepin. Loop the end with 6mm long pin tail. Remove the excess part. Make 7 groups;
2. Thread three pieces cat eye beads onto a long eyepin. Loop the end;
3. String the 8mm cat eye bead onto the headpin along with one 4mm Bicone glass bead. Form a loop at end in same way. Do another 2 pairs;
4. Snip a fraction of brass chain, approximately 5cm.
Step 3:
Place all well-prepared elements on flat as the picture show;
Step 4:
Open the loops at ends and assemble your DIY earrings.
