Introduction: Chain Maille Jewelry - Lucky 7 Möbius Ring
This “Lucky 7 Mobiused Ring” comes together quickly and looks great. Try it in bronze and stainless steel for a challenge or create it in another base metal of your choosing. Here's what you need to make it:
Ring Sizes:
• 7 rings, size T18 BRNZ (18g 3/8″ / 9.5 mm) for large bronze jump rings
• 2 rings, size I18 BRNZ (18g 13/64″ / 5.2 mm) for medium bronze rings
• 12 – 20 rings, size C20 SSTL (20g 7/64″ / 2.8 mm) for tiny steel jump rings
• 5-10 rings, misc 18ga SSTL sizes for small steel rings (for band). Recommended: between size F18 (18g 5/32″ / 4.0 mm) and I18 (18g 13/64″ / 5.2 mm). See TIP at end of instructions.
To create this project, you will need to pairs of flat-nosed pliers. Because this project uses metals that can be a bit harder to work with, we recommend a sturdier set of pliers such these Wubbers Medium Flat Nosed pliers.
Ring Sizes:
Step 1:
STEP 1. Scoop a large bronze ring with a medium bronze and close. Close the large bronze ring, too.
Step 2:
STEP 2. With a new open large bronze, begin to create a möbius unit: weave through the medium bronze ring and then cross through the first large bronze as well. Close the second large ring.
Step 3:
STEP 3. With a new large bronze, repeat step 2, except this time weave through both the previous large rings, and close.
Step 4:
STEP 4. Continue adding large rings, being sure to go through the medium bronze and all previous large bronze rings, until all 7 large rings have been added.
Step 5:
STEP 5. Weave a new medium bronze through all 7 large bronze rings and close.
Step 6:
STEP 6. Now create the band. With an 18ga steel ring, scoop up 2 tiny steel rings. Weave through the bronze ring from step 5, and close the steel ring. Close the tiny steel rings, too.
Step 7:
STEP 7. With a new 18ga steel ring, scoop up 2 new tiny steel rings and weave through the previous tiny rings from step 6. Close all the steel rings.
Step 8:
STEP 8. Repeat step 7 until your band can just about reach all the way around your finger.
Step 9:
STEP 9. Add one final steel ring through the previous 2 tiny rings, but instead of scooping up 2 new steel rings, weave the steel ring through the first bronze ring from step 1. Be sure not to twist the band as you do so.
SIZING TIP: You might need to replace one or more of the 18ga rings you used for the band with a slightly smaller or larger ring. Play around until you’ve got the perfect fit.
