Introduction: Cheap Wooden Cam Holder
hi, here is a simple and cheap way to make a camera holder with 2 laboratory waste, a wooden strip (2cm x 4cm x 150cm), a threaded screw (about 30 cm) and some bolts and washers
tools:
1 grinder
1 table saw
1 jiggle saw
1 column drill (or classic drill)
1 wrench (or a screwdriver with a suitable insert)
Step 1: Project With Sketchup
before starting to cut the wood, to avoid mistakes, I usually do a sketchup drawing to get an idea of what to do
Step 2: Cut the Wood
now that I know what to do I can start to cutting the pieces as I need them.
it takes 6 short pieces (about 8cm) and others 3 long pieces (about 25/30cm,it depends on how much you want both the total length).
remember that the ends must be rounded to allow the strips to rotate.
Step 3:
once all the pieces are cut and perforated we can proceed with the assembly.
Step 4: Final Results
and here is a simple diy camera holder with about 5 € of material
