Controlling LED Matrix Array With Arduino Uno (Arduino Powered Robot Face)
25,629
176
28
Introduction: Controlling LED Matrix Array With Arduino Uno (Arduino Powered Robot Face)
About: Maker, engineer, mad scientist and inventor
This instructable shows how to control an array of 8x8 LED matrices using an Arduino Uno. This guide might be used to create a simple (and relatively cheap display) for your own projects. This way you might display letters, numbers or custom animations.
A 5 matrices array used in one of our robot projects ("Robô da Alegria") is used as an example to ilustrate this technology. You might found more about this project in the following links:
https://www.instructables.com/id/Joy-Robot-Rob%C3%B4-Da-Alegria-Open-Source-3D-Printed-A/
https://hackaday.io/project/12873-rob-da-alegria-joy-robot
https://github.com/ferauche/RoboAlegria
https://www.facebook.com/robodaalegria/
Special thanks to the other team members involved in the above mentioned project, responsible for the first version of the code presented in this tutorial:
Thiago Farauche
Diego Augustus
Yhan Christian
Step 1: Components
The following components were used in this project:
  • Arduino Uno (buy)
  • 8x8 LED matrix array with MAX7219 driver (x5) (buy)
  • Female-to-female jumper wires (4 jumpers of 5 cables each)
  • Male-to-famale jumper wires (1 jumper of 5 cables)
  • 2mm acrylic sheet (optional for fixation of the components)
  • M2 x 10 mm bolts (x20) (optional for fixation of the components)
  • M2 x 1,5 mm nuts (x20) (optional for fixation of the components)
  • A computer (for compiling and uploading Arduino code)
  • Creativity
Notice that you'll need two types of jumpers: female-to-female for the connection between the matrices and a male-to-female for the connection of the firts matrix to the Arduino.
The number of components may vary according to the structure you have in mind.
Step 2: Assembly
Connect all the componets according to the schematic. You'll need some jumper wires to connect the first matrix to the Arduino, and each matrix to the next one on the array.
Arduino Pinout:
  • Arduino digital pin 13 = DIN of the first display
  • Arduino digital pin 12 = CLK of the fist display
  • Arduino digital pin 11 = CS of the first display
  • Arduino 5V pin = Vcc of the first display
  • Arduino GND pin = Gnd pin of the first display
You might also want to arrange each display in a given position. For that you might use a acrilic sheet, some bolts and nuts (four for each display) and place each component in position.
No tool is needed to assemble the circuit, but you will need a screwdriver or sharp tool if you wish attach the displays to a surface with some bolts and nuts. In our example, five displays were placed in a face pattern (two eyes and a mouth).
Plug the USB cable to the Arduino Uno board and proceed to the next step.
Step 3: Coding
With the latest Arduino IDE version installed, add the LedControl.h library, which is used to control the LEDs.
Download, compile and upload Arduino the code, which is divided in 4 parts:
1. Definition of the eyes and mouth: each eye is configured and a 8-byte array. The mouths are defined as a 24-byte array;
2. Setup: configure displays and start communication;
3. Main: wait for serial communication commands and choose which face will be displayed;
4. Auxiliary functions: functions for setting eyes' and mouth's displays.
setRow function was used to set each row of the LED display. It was used instead of setColumn because it runs eight times faster! This way, the drawings for each display have to be declared rotated 90 degrees counter-clockwise.
setIntensity was used to limit LEDs brightness. It was set as 1 (in a scale from 0 to 15) in order to reduce the power consumption of the modules to a level aceptable by the USB port.
Step 4: Usage
After the upload keep the Arduino connected to the USB port of your computer and open the Serial Monitor.
The code is programmed to display a set of emoticons on the LED face, depending on the message received by the serial port.
The following commands were configured:
For the eyes
  • : (normal eyes)
  • ; (blink)
  • 8 (spooky eyes)
For the mouth:
  • ) (happy)
  • | (neutral)
  • ( (sad)
  • D or d (very happy)
  • O or o (surprised)
  • P or p (tongue out)
Type a pair of characters (one for the eyes and other for the mouth) in the serial monitor, press enter and the displays will be updated according to your command.
You might change the drawings (add new faces for instance) or change the control method (including a bluetooth or wi-fi interface), according to your needs.
Have fun!
Maker Olympics Contest 2016
1 Person Made This Project!
  • Game Design: Student Design Challenge
  • Make It Bridge
    Make It Bridge
  • For the Home Contest
28 Comments
zpoonz.zpoonz
zpoonz.zpoonz
3 years ago
i made this led matrix face with the kids at work...
how do we make the animated eyes (blinking ones ?? )
thanks
zpoonz.zpoonz
zpoonz.zpoonz
Reply 3 years ago
someone??
suelks
suelks
4 years ago
What is done with the FLPMR9JIRKFL3VQ.FZZ
IgorF2
IgorF2
Reply 4 years ago
Not sure if I understood your question. Could you please clarify?
FernandoC262
FernandoC262
Reply 3 years ago
Lo que quiere decir es que en ese paso tenemos que descargarlo ese para que es ?
IgorF2
IgorF2
Reply 3 years ago
Hi there. This .fzz file is a Fritzing file. It displays the diagram on how to connect the LEDs to the Arduino.
The conde you should upload to the Arduino is the LEDdisplay.ino file you can find in Step 3.
Please verify.
FernandoC262
FernandoC262
3 years ago
buenas Estoy haciendo ese proyecto pero tengo problemas espero me ayude primera ya cargue el programa a la placa ya conecte todas las matrices las 5 pero no enciende ninguno tambien la libreria esa q muestra la imagen es que ya la inclui pero no prende ninguno yo use el codigo FEGF6QQIRKFL5XL.ino es ese o me equivoco de codigo EN donde dice include estan la led control pero los dejo esas 2 o no por q la que descargue fue la que aparece en color anaranjado
BigGene
BigGene
Question 4 years ago on Step 2
Still working on the bigger robot project and troubleshooting my LED face matrices. I see this guidance in your instructions:
  • Arduino digital pin 11 = CS of the first display....Isn't CS actually connected to digital pin 10 since there is a zero "0" digital pin to account for?
suelks
suelks
4 years ago
relaque is done with the FLPMR9JIRKFL3VQ.FZZ
sanidhya_shetty
sanidhya_shetty
5 years ago
hello IgorF2,
im getting fatal error, what to do about it
IgorF2
IgorF2
Reply 5 years ago
Hi there,
Can you give me additional information? Did you add the libraries, and chose the right Arduino board before compiling and uploading the code?
PeckLauros
PeckLauros
5 years ago
Boa! Colocando um receptor Bluetooth seria um upgrade legal também.
Dillonwest
Dillonwest
6 years ago
hi, I made one of these and am now wondering if there is any more information on programming it. Any links or even books I could purchase that would help would be great! Thanks!!
Dillonwest
Dillonwest
Reply 6 years ago
I mainly need help with how I would go about changing the code to use different faces, and have it on a change mode button to switch them.
IgorF2
IgorF2
Reply 6 years ago
Let me see if I understood correctly: you want to design some new faces and switch them by pressing a physical push buttons? If that's the case, I can try to help you.
Regarding your other comment, there is a lot of books and tutorials available online. Most of the times you can find the solution to your problems on online forums as well. You can also learn a lot from the examples available on Arduino IDE.
Dillonwest
Dillonwest
Reply 6 years ago
yes, on my standalone atmega328 board I have a button connected to pin #4 as a 'switch mode' button. I have all my boards assembled and connected, just need to get the atmega328 programmed. I don't have much experience with arduino, I'll be sure to look at the examples on arduino ide. Thanks!!!
IgorF2
IgorF2
Reply 6 years ago
I see. I think that basically you'll have to check if the button is pressed. If it is, incremment an integer, which is compared to select the face.
I can help you with the code, if you need it.
chopperaddict
chopperaddict
6 years ago
Nice one, but a circuit diagram would have helped those of us that have never set one of these things up ? The 3D view is OK but doesn't really show exactly what pins on the arduino go to the LED display ?
IgorF2
IgorF2
Reply 6 years ago
Thanks, chopperaddict. I didn't notice that the resolution of the schematic wasn't good (it is impossible to see the number of the pins). So I added two more images on Step 2: a zoom showing the connection of the Arduino to the first display, and a detail showing the connection between first and second displays. I also added a pinout description. I hope it helps.
Fritzing circuit diagram for the LED display isn't very intuitive. You can check it out in the Fritzing file on Step 2.
Please let me know if there is something else you think I should improve. :D
