DIY Entwine Wire Wrapped Rings for Women
3,072
120
Featured
Introduction: DIY Entwine Wire Wrapped Rings for Women
In this entwine wire wrapped ring patterns, you will learn the wire wrapping technique and gain the way to create an awesome work, send it to your loved one as a gift, she will be surprised by your idea.
Step 1: Supplies Needed in Making Wire Wrapped Rings:
6mm Glass Beads
1.5cm Aluminum Wire
0.5mm Copper Wire
Wire Cutter Pliers
Round Nose Pliers
Side Cutting Pliers
Step 2: Step1: Make the Half-heart Shape Component
1st, prepare 2 length of 25cm aluminum wire, coiling wire with round nose plier about 2or 3 wraps, then do the same at the distance of 3cm from the first coil , you will get patterns like pictures shows;
2nd, repeat 1st in step1 to make another one.
Step 3: Step2: Connect the 2 Ring Base Wire Together
1st, prepare length of 80cm copper wire, then start wrapping the wire to intertwine the 2 ring base together;
2nd, here I wrap about 7cm according to my index finger, then cut off the extra wire;
Step 4: Step3: Make Patterns at the Other Wire Ends
1st, rotate wire outside with round nose plier about 2 or 3 wraps, then rotate wire inside about 2 or 3 wraps at the distance of 2mm from the first coil;
2nd, do the same as 1st in step3 on the other line.
Step 5: Step4: Add Glass Beads to the Ring
1st, take length of 8cm copper wire, then Wrap about 3 times to the coil;
2nd, slide 1 glass bead onto it for embellishment, and fix it by wrapping the wires to the opposite coil, cut off the extra wire;
3rd, repeat 1-2 in step4 on the other end to finish the entwine wire wrapped ring.
Step 6:
Tada! We have finished this entwine wire wrapped ring! Amazing, right? If you like my craft, please stay focus on my following articles! Have a nice try!
3 Comments
6 years ago
Cool
Reply 6 years ago on Introduction
Thanks
Nice, but you my wanna correct the diameter of the alu-wire (1.5cm is a bit much between your fingers ;)
