DIY Plunging Halter Top (No Sewing Required)
5,560
26
Introduction: DIY Plunging Halter Top (No Sewing Required)
About: Making things, going places, doing stuff. Join me :) Contact: mgjmedia@gmail.com
Here is an extremely quick and easy DIY way to transform a basic fitted shirt into a plunging halter top with no sewing! Another fun project for summer. Enjoy! :)
Full video tutorial:https://www.youtube.com/watch?v=-45k_rV0KKg
Step 1: Gather Materials
What you'll need:
*Miaira is a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for sites to earn advertising fees by advertising and linking to Amazon.com.
Step 2: Draw Plunging "V" Shape
Start with the shirt on backwards since the collar will be higher up and there is more material left later once it's time to cut. Then, use the pencil to mark the spot where you want the plunge to end.
Next, take the shirt off and draw out the rest of the "v" shape using a straight edge (I've got my handy oreo box).
Step 3: Cut Front Halter Shape
Take your scissors and cut the "V" shape from the front. Then, starting on one side of the top, cut down and over to about 2 inches below the armpit. This will create the first triangular shape of the halter top. Repeat this to the other side and the front of the top is complete!
Step 4: Cut the Back
Now, fold the front over so it's out of your way and simply cut straight across the back, removing that top portion of material. The base of your halter top is done!
Step 5: Cut Straps
Using that same portion of material that you just cut from the top of the shirt's back, cut along the collar. Then, cut that strip in half. These will be the straps for the halter!
Step 6: Attach Straps
Use your scissors to cut a small slit into the top of one of the front triangular flaps. Then, slip the end of one of the strips through the hole and tie a knot. Repeat on the other side and your halter is ready to try on!
Step 7: All Done!
That's it!! You now have a fun plunging halter top that required zero sewing and just a few minutes of work! Thanks so much for checking out this tutorial and please leave a comment if you try it out! :)
Video: https://www.youtube.com/watch?v=-45k_rV0KKg
YouTube: https://www.youtube.com/miairajenningstv
Instagram: https://www.instagram.com/miairajennings/
Twitter: https://www.instagram.com/miairajennings/
Website: https://www.instagram.com/miairajennings/
Be the First to Share
    • Chocolate Challenge
      Chocolate Challenge
    • Electronics Contest
      Electronics Contest
    • Stone Concrete Cement Contest
    2 Comments
    _Hot_Rod_
    _Hot_Rod_
    5 years ago
    awesomely done, and very beautiful.
