DIY RC Shock Breaker Mod
Introduction: DIY RC Shock Breaker Mod
Radio controlled toy car is very popular these days. But the sparepart of these toys are sometimes very expensive, for example the price of the oil shock breaker for drift rc car is $29.59 (Rp. 350.000). This tutorial will show you how to mod the suspension of the RC car to get better traction and control
Step 1: The Tools
1. The RC (Tamiya TT01 or the replica
2. Plus (+) and wide minus (-)screwdriver.
4. Salvaged spring from old RC car. Should be fit inside the barrel of the shock breaker.
Step 2: Open Up and Unscrew the Shock Breaker.
I'am going to mod the front shock breaker so the car will get better control. Open the body of your RC and unscrew the upper and bottom screw of the shock breaker.
Step 3: Release the Standard Spring From the Barrel.
Release the spring from the barrel by pushing the barrel and twist it clockwise. Be careful, sometimes, the spring will jump away.
Step 4: Put the Salvaged Spring.
I the frist picture, you can compare the size of the standard srpring (the big one) and the salvaged spring. The standard spring are harder than the salvaged spring and did not actually good because its too hard, but the salvaged springs are softer, you'll get more flexible shock breaker than the standard.
Put the salvaged INTO the barrel and close the barrel by pushing the lower part and twist it counterclockwise until it locked.
Step 5: The Scheme
Step 6: Put Back the Shock Breaker.
Put back the shock breaker and your RC is ready for some action.
Thanks for reading and sorry for my bad english :9
Be the First to Share
    • For the Home Contest
    • Game Design: Student Design Challenge
    • Make It Bridge
      Make It Bridge
    3 Comments
    robdb78
    robdb78
    7 years ago
    I was wondering, doesnt that messup the interior of the shock?
    FajarPradipta
    FajarPradipta
    Reply 7 years ago
    Not really. This trick can only be used on the "plastic" shockbreaker, but if you already have a "metal" or "Oil" shockbreaker, you do not need to use this trick.
    SEKTHEBOSS
    SEKTHEBOSS
    7 years ago
    Cool this would work well on my car
