Introduction: DIY Ruffle Dress
I made a midi loose fit dress with raglan balloon sleeve with a twist lace insertion and ruffles. At the neck has elastic inserted , so you can wear it also on your shoulders. This dress can be made in a variety of fabrics such as polyester or cotton and you can accessorize it with a belt.
- 3 to 5 meters of fabric
- elastic 2 cm wide
- 2 meters of lace
- thread
- sewing machine
- scissor
- some pins
- iron
- serger machine- optional
Step 1:
Take the bodice front ruffle and fold it in half. Sew at 1 cm from the edge with the longest stitch length of your machine so you can make the ruffle by pulling one thread.
Step 2:
Take the bodice front ruffle and sew it on the bodice front ruffle. You have to hold underneath the 1 cm edge and sew
Step 3:
Take the bodice front panel and bodice back panel pin them together (right sides facing in) and sew along the edge
Step 4:
Take the sleeve ruffles and fold it in half. Sew at 1 cm from the edge with the
Step 5:
Take the top part sleeve panel and the top part sleeve ruffle and sew it together
Step 6:
Take the Sleeve bottom part and the sleeve bottom ruffle and sew it together
Step 7:
Take the middle sleeve panel (lace panel) and place it on top of the edges and sew along the edge
Step 8:
Sew the sleeve close- (right sides facing in) and repeat the process for the other sleeve
Step 9:
Sew the sleeves to the bodice
Step 10:
To make the elastic channel along the top of the entire bodice piece and sleeves, measure 4 cm from the top neckline and fold inside of the dress,with 1 cm folded inside. of the channel so you can have a clean edge.
Leave an opening to thread in a piece of elastic that's slightly shorter than the length around your shoulders.
Close the opening
Step 11:
Finish the edge of the sleeve with an overcasting machine and make the channel for the
elastic of 2 cm leaving an opening to insert the elastic, which can be slightly looser than
your wrist measurement.
Close the opening and repeat the process for the other sleeve.
Step 12:
- Take the Front panel ruffle and the back panel ruffle and sew them together (right sides facing in)
- Sew at 1 cm from the edge with the longest stitch length of your machine so you can gather the ruffle by pulling one thread.
- Sew the ruffle to the bodice - right sides facing in
- Make the hem
Step 13:
If you want to make this dress you can find my PDF pattern on my etsy shop https://www.etsy.com/shop/MaryTheDressmaker?ref=profile_header
