Introduction: D.i.y.: Custom-tips for Soldering-iron
a lot of times the tips that come with solder-irons just dont cut it. just make your own. really a ton of material works. here i use the lid of a fish-can (although copper would be better, but i will make a quick & dirt ´knife´-tip for plastic-welding).
__ NOTE: photo above, right, a close-up from a new tip, see UPDATE below
needed:
_ a solder-iron (nobrainer)
_ some kind of (thin) tin - (or just bang down some metal)
_ pliers
Step 1: Create a Piece of ´tube´ From Some Tin
_ cut a strip of metal-tin >
_ roll it up with pliers into a ´tube´ the size of the heating-coil of the iron >
_ flatten the end of the tube/tip; cut/file/grind in into any shape you wish >
_ connect tip with iron, ready
Step 2: Done
(above: parts before assembly)
thank to all.
bowing.
Step 3: Update Jun/25
quick add-on. made a rather fat tip today. made of fishcan/tin. please ask if you have any questions and i´ll post additional info. tschuess.
