Felted Hanging Basket Liner
Introduction: Felted Hanging Basket Liner
With Spring upon us it's time to think about gardening and decorating with flowers in hanging baskets. Most metal hanging baskets come with cocoa fiber linings that quickly wear out after a season or two. Instead you can make this 100% wool felted liner that will last for several seasons and can even be washed and re-used of necessary.
100% wool (feltable) yarn - 8 oz.
Yarn needle
Crochet hook (K)
Scissors
Metal hanging basket frame
Scrap yarn (polyester/acrylic)
Step 1: Crocheting
Using your favorite or free pattern and a large crochet hook (K), crochet a 24" square granny style out of 100% feltable pure wool yarn in knitting worsted weight. Finish off your square by crocheting all around the square in a backwards fashion and tie strands together as you make your square. For this step you can use a contrasting color of scrap wool yarn.
Step 2: Felting
Set your washer to hot temperature and on a short cycle. Add the granny square and a few towels to the washer so that the machine can do the felting for you. You may have to repeat this a couple of times until the granny square shrinks to about 20" side to side. Use a yarn needle to weave polyester/acrylic yarn diagonally through the holes in the granny square. You can leave extra yarn at the ends of each side that can then be used to tie the liner to the metal hanging basket.
Step 3: Weaving
Step 4: Finishing
Place the liner into the hanging basket and use the loose yarn ends to tie it to the basket or use polyester/acrylic yarn to sew the liner into the basket. You can also add some plastic wrap to the bottom of the liner before you add soil and flowers to reduce the chance of soil leaking out.
Fiber Arts Contest
Fiber Arts Contest
Be the First to Share
    • Big and Small Contest
    • Game Design: Student Design Challenge
    • For the Home Contest
    2 Comments
    Penolopy Bulnick
    Penolopy Bulnick
    2 years ago
    This is cute and such a fun and simple idea to weave the yarn through :)
    You should consider entering this in the Fiber Arts Contest :)
    oborys49
    oborys49
    Reply 2 years ago
    I did
