Introduction: Fixing Samsung Galaxy Tab Broken Cable Charger
i create this fixing guideline because i've been confuse when my cable charger was broken and i cant find any instruction on search engine about fixing this stuff.
Cable for Samsung Galaxy Tab is similar with my actually gadget, Galaxy note 10.1 [GT-N8000].
OK .... lets start it
Step 1: What You Need
1. broken cable it self
2. cutter
3. tweezers
4. solder set
last touch misc [i use]
1. tape
2. ethyl cyanoacrylate [liquid glue]
3. tissue or fabric
Step 2: Cut the Vessel
Step 3: Connect the Unconnected
watch carefully for unconnect cable ...
find it and soldering this on to this rite place :)
in my stuff ... the rite place is the tin point are not have any wire go to front ... only tin spot ... look my sketch for info side by side cable
use only hot tip soldering tools for open the wire ... [ 1st i use razor and unlucky to cut them off .. lol ]
check this 1st before you assemble all opened pieces together
i have two charger and both was end with this same problem ... unconnect green wire
is this some of samsung failed charger product?
Step 4: Test That
before plug in cable charger to your device ... look on your battery percentation ... remember it ... plug your charger in and wait till view minutes. if everything correct, the battery percentation would rise.
MAKE SURE its truly fixed !!!
if after more than three minutes and battery percentation doesnt goes up ... re check your work and find something not connected well .... and fix it
to make sure everything was back to normal ... let this repaired cable make your device fully charge.
good?
ok ... lets do final step
Step 5: Finishing Touch
until all have done and runing normal ... do this step to make our repaired cable tough enough for our daily use
after all part was assembled .... use your tape to covered all this stuff surface to avoid of glue damaging important parts if one time you need to repairing again.
basicly ... depend on what material you want to use to covering this stuff
[ e.g epoxy, resin, palstic, putty, product package, etc ]
i choose ethyl cyanoacrylate and combine it with cut off fabric .... put lill bit glue to stick fabric before we can covering this area .... until it covered by fabric .... drop liquid glue on it .... only to make fabric wet and stick to charger
do it layer by layeruntil you feel enough .... and let it dry and being hard
and all done
thanx for looking
and perhaps this is usefull for you :)
2 People Made This Project!
- batmat made it!
- claudiopolis made it!
12 Comments
5 years ago
i am not able to differentiate with top and bottom of the connector (charger)
6 years ago
my galaxy tab 2 , 7.0 . 8g. Its modle gtp 3113. Charge cord lasted for 2 ys. Then I had to wiggle it so Now I go to best buy.. and pay 25 30 dollar's for just the cord... no wall plug! Also.... duracell has a ultimate universal charger. ?... the pack says fir samsung , droid ,I phone, apple, and many others....so I buy it....8 dollars. why not..ya know......and.... nope.. it wont fit anyway I try . every way. ? M ......realy #samsung #bestbuy what is the difficulty? Or am I the only person who still has a galaxy tab 2? Willing to pay 30 $for a cord cus thats where my music and vids ar at.................best buy needs rehab. They're money junkies not geek help.
6 years ago
Now I am thinking that your post will be more attentive for me as all these information will definitely help me to use Samsung Galaxy tab in a proper way. Apart from that I have a Samsung galaxy phone and I have using a Samsung Galaxy Charger that ordered from an online store as Mobansp. Thanks for sharing such information over Fixing samsung galaxy tab broken cable charger.
6 years ago on Step 3
Is there a way to make a charger that will work with the Galaxy Tab 2 with a generic iPhone Charging cable?
6 years ago on Introduction
What an obnoxious quality blunder by Samsung!
Thanks a lot for the info! I was worried that the port on the tablet had gone south on me... instead I have now confirmed that my cable actually failed (thank god) thanks to your guide!
7 years ago on Introduction
Yeah! Now that they're getting more difficult to find, I've managed to kick it a little further down the road. Thanks!
my dad and me did the exact same thing last year to fix my charger. I can't believe this is actually the problem to all the glitches my tablet got when i was charging, guess ill do the same thing today! this deserves more views
who ever need to fix this problem .. they can see this page from google
glade to help ^_^
This helped me out so much. Thank you very much.
your welcome ... glade to help others ^_^
8 years ago
sadly it isn't my dog chewed mine into 20 pieces
sorry to knew that ... nothing can do except to buy new one :D
