Introduction: Glittery Tube Necklace
Here's a fun, easy jewelry idea that requires no additional skills. It's called the Glittery Tube Necklace, and it's a great project to make and sell at a very low cost!
Step 1: What You'll Need
Here's what you'll need to make your own Glittery Tube Necklaces
- a block of grey oven bake clay
- bamboo skewer
- X-acto knife or plastic clay knife
- acrylic paint (I'm using blue)
- oil based Sharpie marker
- silver or gold chain
- clear glaze
- clear tape
- tiny paint brush
- glitter
- Mod Podge
Step 2: Prep the Beads
First, roll out your clay into a thin, small snake. Then, cut that about 1 to 2 inches long with your X-acto knife. Now, you're going to make a hole in the beads by pushing a skewer through the center of the bead. You might want to wiggle around to make the hole large enough for the chain to pass through.
Step 3: Bake the Beads
Now, pop the beads in the oven and bake according to the package directions. My clay bakes at 275 degrees for 15 minutes. Once time's up, take them out and let them cool completely.
Note that it may be hard to see in this picture, but what actually happened was that the clay bead kind of burned on top. However, I figured that since I am covering it with paint, gold Sharpie, and glitter anyway, it wouldn't really make much of a big difference!
Step 4: Decorate
Now, it's time to decorate the beads! Place a piece of clear tape around the bottom of the bead before painting to help in making a neat line. Now, paint the end of the bead with your small paint brush and let dry completely. Then, once dry, draw a thin border with your Sharpie marker. You can also add glitter, just like how I did here in the third photo.
Once you're done, take them outside and glaze your entire beads and allow to dry.
Step 5: String and Wear!
Once your bead is dry, string a chain through the center of the bead, and it's ready to wear!
