Introduction: Headset Stand
I use a headset at work but it normally lives just laid on my desk. Due to the coronavirus I am currently working from home so have my normal work layout in my living room. A stand for the headset would be perfect so this seemed to be there perfect time to make one.
Materials
Wood offcuts
Glue
Tools
Saws - band and miter
Clamps
Sanders
Router
Step 1: Concept
I just recently finished making a bread bin out of offcuts and had a few left. My idea was to cut these pieces in to regular sized 5mm thick lozenge shapes and glue them together in to a curved shape.
I laid out some of the wood to determine the rough shape and size.
Step 2: Cut to Size and Shape
I started on the band saw cutting the offcuts to the same width, which ended up being around 5mm (1/5 inch). I then cut them all to the same length on the miter saw.
To create the curved end I drew a semi circle on one of the pieces, with a pair of compasses, and shaped it on a disc sander. I then used this piece to mark the end on all the other pieces.
Step 3: Create a Form
To create my form I used two bits of MDF glued together and backed them with a bit of hardboard.
I started by marking out the shape I wanted and rough cut it on the band saw. I then brought it to it's final shape with a bobbin sander. I then rough cut the second MDF part, glued and screwed it to the first and used a pattern bit on my router to make them the same. I then screwed on the hardboard.
Step 4: Sand
My disc sander does need a new pad so most of the ends were burned so I sanded of the blackened ends using a random orbital sander.
I also sanded all the edges as these couldn't be done once glued.
Step 5: Glue
I decided to glue the stand in parts as I only have three small f-clamps which seemed an ideal size for this job. I laid out three pieces on the bottom layer, four on the next and three on the top, in a stepped fashion like brickwork, only applying glue to the top and bottom layer. These were then clamped.
Once they were dry I worked my way through the rest until it was complete.
Step 6: Determine Next Step
I now had my main form, which was slightly out of balance, although it did stand correctly with the headset on it.
I therefore decided to add a few more lozenge pieces to the foot of the stand together with a base to add a bit more stability.
Step 7: Add Base
I glued some additional lozenge parts in a stepped pattern to the base and clamped then up.
Once it was dry I drew, on a scrap bit of wood around the base and cut it to size on the band saw. I then sanded, glued and clamped it to the rest of the stand.
Step 8: Finish
Now it was all glued together I sanded all the bits I could with a random orbital sander up to 180 grit and added a couple of layers of oil for protection.
I do like the final shape it's kind of scorpion shaped and it's much better then having the headset randomly placed on my desk.
If you liked this instructable please vote for it in the woodworking contest.
Thanks for reading.
