Introduction: Hex Nut Bracelet & Earrings
Hex Nuts Rock!I don't know why but I really love Hex Nuts! When I was a teenager I did my first Hex Nut Earring (which is one of my favorite earrings and I still wear it).
The other day I went to a hardware store and I found very cheap hex nut packs. I had to buy a pair! Since I bought them I've made a lot of jewelry with them (which I will upload progressively).
By the way, in my language, hex nuts are called "females" and I like to wear them as a feminist symbol: a hard and resistent female ready to rock!
Step 1:
You need two pliers, rings and hex nuts. Once you have them you're ready to start!
Step 2:
Take a ring, open it and insert two nuts. Then close the ring.
I'd recommend to close and open the rings with two pliers. It's easier than using only one.
Step 3:
Take another ring, open it and insert one nut and close it.
Step 4:
Repeat the third step as many times as you need to obtain the desired size.
Step 5: To Make the Earrings
To make the earrings I used 5 nuts and an earring hook. But the actual number depends on your particular tastes.
You only need to insert a ring in the last nut and insert the earring hook instead of a nut. And there goes your earring!
Step 6: To Make the Bracelet
In case you want to do the bracelet:
On one end you have to insert a ring (where the lobster clasp will be attached to close the bracelet). And on the other end, insert a ring and a clasp. And here goes your bracelet!
Step 7:
And you're going to obtain a thing like this!
