Introduction: How to Make USB Flash Drive Using an Eraser | DIY USB Drive Case
This blog is about "How To Make USB Flash Drive Using an Eraser | DIY USB Drive Case"
I hope you will like it...
- Big Non-Dust Eraser
- Stationary Cutter
- USB Drive (without case)
- Super Glue
- Marker
Step 1: Measuring and Cutting
Firstly, cut the eraser vertically equally from between. Measure and outline the Pendrive on the eraser and cut it out with the help off the cutter.
Step 2: Cut Out the Eraser As Per Measurements
Now, measure the USB Drive on one of the two surfaces of the eraser and draw the outline of USB on it with the help of a pen/marker. With the help of a blade, scratch the eraser from inside of the eraser surface.
Step 3: Now Cut Out Eraser and Cut Out Eraser for Cap
After it's done, check the fitting of USB in an eraser. Using superglue stick everything...
It's done...
Step 4: Everything Is Done...
Now, everything is done. Your eraser Pendrive is ready.
Check out my website for more projects.
Subscribe to my YouTube channel for more interesting projects.
